Two Satellites in Parallel Orbits
The discussion focuses on calculating the time until two Earth satellites in parallel orbits, with radii of 6700 km and 6701 km, are again 1 km apart after initially passing each other. The orbital periods were determined using the formula T² = (4π²r³)/(GM), yielding T1 ≈ 5456.053 seconds and T2 ≈ 5457.274 seconds. The angular velocities were calculated as ω = 2π/T, leading to the relationship Δθ = t(ω₁ - ω₂). The solution involves setting Δθ equal to 2πn, where n is an integer, to find the time t for the next rendezvous.
  • Understanding of orbital mechanics and satellite motion
  • Familiarity with the gravitational constant (G) and mass of Earth (M)
  • Knowledge of angular velocity and its calculation
  • Ability to manipulate equations involving circular motion
  • Study the derivation and application of Kepler's laws of planetary motion
  • Learn about the gravitational constant and its role in orbital calculations
  • Explore the concept of angular displacement in circular motion
  • Investigate the effects of varying orbital radii on satellite synchronization
Aerospace engineers, astrophysicists, students studying orbital dynamics, and anyone interested in satellite motion and rendezvous strategies.
LovePhys
Two Earth satellites are in parallel orbits with radii 6700 km and 6701 km. One day they pass each other, 1 km apart, along a line radially outward from the earth. How long will it be until they are again 1 km apart?
s=r*θ
I have an idea that when the two satellites are again 1km apart, they should have the same radian measure. Therefore, if s_{1}=r_{1}θ and s_{2}=r_{2}θ, then \frac{s_{1}}{r_{1}}=\frac{s_{2}}{r_{2}}. But this is just a proportion and I can't find a way to the time required.
At the moment, I have an idea of substituting a value for s2 and then find s1. Then I compare the time taken by each satellite to cover the required distance, if they two values of time do match, then it will be the final answer...
s=r*θ
Can you find the orbital period for each satellite (the time it takes to complete one complete orbit)?
AM
@Andrew Mason
Thanks for your reply.
Yes, I have found the orbital period for both using the equation T^2=\frac{4\pi^2r^3}{GM}, specifically T1≈5456.053s and T2≈5457.274s. Yet, I still cannot see how this helps...
Think about the rendez-vous situation in terms of the orbital angle. Let's say at the initial rendez-vous the angle was zero for both satellites. What will it be at the next one?
LovePhys said:
@Andrew Mason
Can you now express the angle between their respective radial vectors as a function of time? (hint: find the difference in angular velocity and relate that to the angle between their respective radial vectors).
AM
@voko and Andrew Mason
Thank you very much.
I can easily find angular velocity ω=\frac{2\pi}{T}. Also, since this is uniform circular motion, I then think that θ=ωt, so the angle between radial vectors as a function of time is: \Deltaθ=t(ω_{1}-ω_{2}). But \Deltaθ=0 only when t=0 (initial condition). Please tell me if I am missing something...
Thank you!
What about ## \Delta \theta = 2 \pi n ##, where ## n ## is integer?
@voko
Yes! Why didn't I think about that? Thanks a lot, I got the correct answer! Now I just let n=1 and then find t. :)
