Two Springs & Hooke's Law: Effect on Elastic Electrical Lead
1 reply · 2K views
Laxbro112
So I am doing tensile testing on an elastic electrical lead for biomedical purposes. The lead is encapsulated in an elastic tubing. Now the lead acts like a weak spring itself (coiled wire).
I'm curious, if there are two springs with different k constants "within" each-other (one inside the other) will it effect the Hooke's law equation? Or will the dominant k constant be the baseline?
If you have two springs with the same k embedded into each other, what would happen? I think since the density of the spring is changed, you would have a greater stiffness. Would you use 2k and just add the two? If the springs were separate and working together you could assume that they work together.
Using
## F = k_1X_1 + k_2X_2 ##,
you can see that if the displacement is the same, the effective k is the sum of the two.
If the second is much weaker than the first, ignoring it will likely not induce a significant error.
