Two-Step Mechanism: A + B -> D
  • Thread starter Thread starter nothing123
    Mechanism
In a two-step reaction mechanism, the rate of the overall reaction is determined by the slow step, which involves the intermediate C. While A and B are zero order in the rate equation, adding or decreasing their concentrations can influence the concentration of C, thus affecting the reaction rate. If A or B is added at equilibrium concentration, it does not shift the equilibrium but can still impact the rate due to the relationship between A, B, and C. The discussion highlights that the concentrations of A and B influence the formation of C, which is crucial for the rate-determining step. Ultimately, the reaction can be first order in A and B if the first step reaches equilibrium quickly compared to the second step.
nothing123
Hi,
So if we have a two-step mechanism that goes something like this:
1) A + B -> C
2) C -> D
A + B -> D
and the second step is the slow step, the reaction rate would be r = k2[C] correct? Well, seeing as reactants A and B are zero order, varying their concentrations wouldn't affect the rate. However, one of the questions I encountered said if you ADD A or B or DECREASE A or B, the rate subsequently increases and decreases respectively. I understand the reasoning for this since more A or B would drive the reaction to the right and thus increasing the concentration of intermediate C, which is important in determining the rate. But really, what's the difference between varying the concentration of A or B and adding A or B; if we add A, are we not effectively increasing its concentration?
I got to second question kind of related to this. We have a reaction A + B -> C with equilibrium constant: Kc = [C]/[A]. Now, if we add reactant A, BUT at the same concentration as the equilibrium concentration, then according to the equation, the reaction does not shift to the right, correct?
Thanks.
if A and B are solids, then, adding either of them to the reacting solution would increase their concentration, and shift the equilibrium more to the right. you are increasing the number of moles of A or B, but keeping the volume fixed.
if A and B are solutions, then the concentration does not change. if you add 10 cm3 of 1 M HCl to 30cm3 of 1 M HCl, then you get 40cm3 1 M HCl. the concentration does not change. there is no change in reaction rate.if the concentration of A at equilibrium is x M, and the concentration of the additional A you add is also x M, then the concentration of A in the solution does not change.
The thing is though, A and B are not part of the rate-determining step so technically even increasing either of their concentrations should not affect the rate 9ince they are zero order no?
The concentration dependence on A and B are not zero order as they affect the concentration of [C]. In other words, [C] is a function of [A] and [ B]. For example, if you assume that step 1 reaches equilibrium much more quickly than a turnover of step 2, then [C] = K1[A][ B], where K1 = k1/k-1 is the equilibrium constant for reaction 1. In this case, your rate equation becomes:
rate = k2K1[A][ B]
and, the reaction is first order in both A and B.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
