Friction: Force & Electromagnetic Nature
Friction is not a force applied to a particle but arises from electromagnetic interactions at the atomic level between surfaces. At the macro level, it involves small surface projections colliding, while at the micro level, it relates to the electric fields of protons and neutrons. Friction can occur even with zero or negative normal force, as seen with adhesive tape. Interestingly, adding water can sometimes increase friction, contrary to its usual role as a lubricant. Understanding friction involves examining both macro and micro perspectives of surface interactions.
manimaran1605
What kind of force is Friction, force applied on a particle? Are these are Electromagnetic in nature?
Friction doesn't apply to a particle.
But in general, yes, frictional forces ariss from electromagnetic interactions between the atoms at the surface of the two objects.
Likes 1 person
It really depends upon which "level" you are looking at. From the "macro" level, friction is small projections in the surface hitting and perhaps breaking off against small projections in the object. From the "micro" level, it is the electric fields of the protons and neutrons pressing against one another.
Likes 1 person
Friction can be quite interesting. The Wikipedia article mentions situations when you can have friction even with zero or negative normal force. It gives adhesive tape as an example. Sometimes adding water (normally considered a lubricant) can also increase friction. For example many people lick their fingers when trying to turn the pages of a newspaper.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 29 ·
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 77 ·
