Udemy Quiz Question on Radians and Quadrants
  • Context: High School
  • Thread starter Thread starter Simone
    Angles Quiz Radians
The discussion revolves around determining the location of an angle of 10.5π radians in standard position, exploring the conversion between radians and degrees, and the implications of using radians versus degrees in mathematical contexts. Participants engage in clarifying concepts related to angles, rotations, and the significance of π in these calculations.
  • Some participants suggest that dividing 10.5π by π simplifies the problem, leading to an understanding of the angle in terms of full rotations and additional fractions of a circle.
  • Others express confusion about the relationship between radians and degrees, questioning how to convert between them and the significance of π in these calculations.
  • A participant mentions that 10.5 radians is approximately 601.1 degrees, indicating a potential misunderstanding of the conversion process.
  • Some participants discuss the advantages of using radians over degrees in mathematical formulations, citing the elegance of results in calculus and trigonometry.
  • There are inquiries about the concept of derivatives in relation to the sine function and how radians simplify these expressions.
  • Several participants express frustration with their understanding of the topic, indicating a desire for clearer explanations and step-by-step guidance.
Participants generally express confusion and seek clarification on the topic, with no clear consensus on the best approach to understanding the relationship between radians and degrees or the implications of using π in calculations. Multiple competing views remain regarding the conversion processes and the conceptual understanding of angles.
Limitations include varying levels of understanding among participants, differing interpretations of the significance of radians versus degrees, and unresolved questions about the mathematical steps involved in conversions.
This discussion may be useful for students learning about trigonometry, educators seeking to clarify concepts related to angles, and anyone interested in the mathematical implications of using radians in calculations.
Simone
TL;DR
Why is the answer "on the positive vertical axis" and not "in the third quadrant?" the question on the quiz is: Where is an angle of 10.5π radians in standard position located?
Is there a difference between 10.5 radians and 10.5π radians?
I am so stupid, this question makes me want to cry.
Question: Where is an angle of 10.5π radians in standard position located?
A. On the positive vertical axis
B. On the negative vertical axis
C. In the second quadrant
D. In the fourth quadrant
I thought I had to divide 10.50 by 3.14, which I thought yielded 3.34π. Then I subtracted 3.34π by 2π to get 1.34π. That is 3rd quadrant.
I also tried 3.34π times 180° which yielded 601.2°. That is also in the third quadrant. Clearly not an answer choice.
I hate how stupid I am. I don't know why I can't understand such a simple question. Please explain in simple terms, step-by-step.
Mathematics news on Phys.org
Correct IF THERE WAS NOT A MULTIPLIER OF ##\pi = 3.14159##. But there is a multiplier of ##\pi##, so it is easier. ##10.5\pi / \pi = 10.5## That is 5 full circles plus one-fourth of a circle in the counterclockwise direction. That is on the positive vertical axis.
How are 10.5 radians and 5.25 rotations? By dividing 10.5π by π it becomes radians without pi... so would I then still divide by 3.14 since the multiplier is gone? I feel I am missing something fundamental here, im sorry.
Why did you divide by π instead of 2π? How did you know to divide by any multiple of π in the first place? How did you get 5.25 rotations from 10.5? What do you mean by a multiplier of π? Is there a difference between 10.5 radians and 10.5π radians? If so, what is it?
The difference is that ##10.5\pi## has a multiplier of ##\pi=3.14159265358979....##. That is quite different from 10.5
##10.5\pi = 32.9867228626928##.
Now you can proceed as you did before and divide 32.9867228626928 by 3.14159265358979, but it is easier to just leave ##\pi## there symbolically so that it cancels cleanly with no calculations: ##10.5\pi / \pi = 10.5##.
Is there a difference between 10.5 and 10.5 * ##\pi##?
For a problem like this, it's better to just visualize the Unit Circle instead of trying to plug in numbers for ##\pi## -- Just remember that there are ##2 \pi## radians in a a circle, and the rest is easy:
https://precalctrig.weebly.com/4-unit-circle.html
… And just in case you ever wonder why such impractical way to measure angles has been used:
”In calculus and most other branches of mathematics beyond practical geometry, angles are measured in radians. This is because radians have a mathematical naturalness that leads to a more elegant formulation of some important results.
Results in analysis involving trigonometric functions can be elegantly stated when the functions' arguments are expressed in radians.”
Copied from
https://en.wikipedia.org/wiki/Radian
:cool:🎄
10.5 π radians represents 5.25 rotations. 10.5 radians represents and angle of about 601.1 degrees.
Why would you want to divide 10.5π by π?
No. ##\pi## is the 3.14 (actually it is 3.14159265358979.... ) So rather than multiplying out the ##10.5\pi## and then dividing by ##\pi##, it is simpler to just symbolically cancel the ##\pi##s.
I did not like the concept at 16, why do it like that? Why not just degrees?
Perhaps it was not explained that well? Other guys got it so it was probably just me!
Perhaps we should use ##\tau## instead of ##\pi##?
https://tauday.com/tau-manifesto
  • Wow
So that the fourth derivative of the ##\sin## function is the ##\sin## function instead of the fourth power of ##\frac{\pi}{180}## times the ##\sin## function. Well, that and a few thousand other things where radians keep factors of ##\pi## and ##180## out of our formulas.
  • Wow
Fourth derivative? Is that snap crackle or pop?
It will be one of those. Let us see which....
If we normalize a particle in simple harmonic motion to an angular frequency of one positive radian per time unit, a phase of zero at time zero and an amplitude of one distance unit then the position function will be ##x = \sin t##
The velocity will be ##v = \cos t## (first derivative of ##\sin t##).
The acceleration will be ##a = -\sin t## (second derivative of ##\sin t##)
The jerk will be ##j = -\cos t## (third derivative of ##\sin t##)
The snap will be ##s = \sin t## (fourth derivative of ##\sin t##).
Conveniently, there are no factors of ##\pi## or ##180## anywhere except in the step where we normalized things.
Edit: Changed position from "##s##" to "##x##" to avoid the conflict with snap.
  • · Replies 29 ·
11K
