Unbalanced three-phase w. neutral. Finding currents
EVriderDK
I have to find the currents in the three phases and the neutral.
I understand that it has got something to do with Kirchoffs law, but how on earth?
I can simulate it in multisim, and i get the right results for I_rms but i cannot figure out how to calculate.
N->L = 220V
L->L = 380V
Here is the layout.
Multisim schematic of an unbalanced three-phase wye circuit with a neutral wire, source V1 labelled 220 V 50 Hz, resistors R1 76Ω, R2 55Ω and R3 88Ω on lines L1, L2, L3 and N, with current probes and yellow readout boxes.
I found the I_L3 just by using I=U/R. I found it to be 2.5A
What are V1-1, V1-2 and V1-3 in complex notation? The rest is just cranking thru the KVL or KCL equations, whatever lights your bulb ... :-)
A slightly rearranged schematic may make things more obvious:
Circuit schematic of an unbalanced three-phase wye load with neutral: three AC sources Vb, Va, Vc at 220V with phases 120 and 240 degrees, each feeding a resistor of 76 ohm, 55 ohm and 88 ohm, with the neutral point at 0V.
You should be able to apply either mesh or node equations. Note that it might be worthwhile to recognize that you have the potentials at each end of the load resistors by inspection...
Va, Vb, Vc are the three-phase line voltages. Write them in complex form and then it's just plug 'n chug.
  • Circuit schematic of an unbalanced three-phase wye load with neutral: three AC sources Vb, Va, Vc at 220V at 0°, 120° and 240°, 50 Hz, feeding 76 Ω, 55 Ω and 88 Ω resistors to a 0V neutral node.
