Unbounded Seq.: 3 is an Upper Bound
  • Thread starter Thread starter fishturtle1
    Sequence
The discussion revolves around the concept of an unbounded sequence with 3 as an upper bound, and the stipulation that no number less than 3 can serve as an upper bound. Participants explore the definition of unbounded sequences and clarify that while a sequence can be unbounded, it can still have an upper bound like 3. Confusion arises regarding the notation and the implications of the requirement that no β < 3 is an upper bound, which leads to the conclusion that 3 must be included in the sequence. Ultimately, the participants agree that the phrasing of the problem may be poorly worded, but they clarify the mathematical principles involved.
fishturtle1
Either give an example or show that no example exists.
An unbounded sequence for which 3 is an upper bound, and no β < 3 is an upper bound.
example: {k}3k=-∞
and by this notation i mean that k starts at -∞ and ends at 3, and k∈ℤ .
I chose -∞ as the lower bound because I wanted this sequence to be unbounded. Then I chose 3 as the upper bound because that is what the original statement asked for. My questions:
Does this example fulfill the original statement because I am unsure of what the question means by "and no β < 3 is an upper bound." The book uses β as the upper bound in previous pages.
Also does the way I wrote the sequence mean what I want it to mean? Because I am also confused on the notation.
How can an unbounded sequence have an upper bound?
fishturtle1 said:
example: {k}3k=-∞
Can you list the first, say, five terms in this sequence?
I chose -∞ as the lower bound because I wanted this sequence to be unbounded. Then I chose 3 as the upper bound because that is what the original statement asked for.My questions:
example: {k}3k=-∞
Perhaps an "unbounded sequence" means what everybody else calls an "infinite sequence". An infinite sequence can be bounded or unbounded.
example: {k}3k=-∞
If you mean what I think you do, a better way to write it would be ##a_k = 4-k,~k = 1 ..\infty##.
Likes fishturtle1
This is the definition of an unbounded sequence I've been using from online,
a sequence is bounded if it is bounded above and below <=> if ∃k∈ℝ such that | xn | ≤ k ∀n∈ℕ.The first five terms in this sequence would be
-∞, -∞+1, -∞+2, -∞+3, -∞+4I was thinking that an unbounded sequence can have an upper bound if it goes to infinity in some direction but converges to a number as well.
I checked the answer in the back of the book, and the answer is fn=3-n which seems similar to ak=4-k, k=1...∞.
I think I would have gotten this same answer had the original statement been " An unbounded sequence for which 3 is an upper bound ".
I'm still confused by the bold part: "An unbounded sequence for which 3 is an upper bound, and no β < 3 is an upper bound. "
I think that it means no number less than 3 can be an upper bound, but isn't this redundant since we said 3 is an upper bound in the first part of the statement?
No, these aren't numbers.
They are the same, assuming ##n## starts at ##0## in ##3-n##.
No, it isn't redundant. Since ##3## is a term of the sequence, no number ##x## less than ##3## can be an upper bound. How could it be if ##x < 3##?
This sequence is bounded since all of the terms are less than or equal to 3.
I think the problem is poorly worded.
Aren't you confusing "bounded above" with "bounded"?
I don't think so. The definition of bounded sequence I am using is that it is a sequence that is bounded above and bounded below. That is, for some M > 0, |an| < M for all n in Z+ (or similar restriction on n).
See https://proofwiki.org/wiki/Definition:Bounded_Sequence
LCKurtz said:
They are the same, assuming ##n## starts at ##0## in ##3-n##.No, it isn't redundant. Since ##3## is a term of the sequence, no number ##x## less than ##3## can be an upper bound. How could it be if ##x < 3##?
Ok I think I get it. So we're told 3 is an upper bound. That means that the greatest number in this sequence is less than or equal to 3.
we're also told that no number less than 3 is an upper bound.
Therefore 3 must be included in this sequence.
If we were not told that no number less than 3 is an upper bound, then our sequence could have been something like xn=-10-n, n=0 . . ∞
Am i understanding this correctly?
Then why do you say in post #9 that ##a_k = 4-k,~k=1..\infty## is bounded?
Yes, almost. You could have it true if the sequence just got arbitrarily close to ##3## but less than ##3##.
Ok, thank you both for your help, helped me a lot on this question .
I should have said "bounded above."
Right. That's what I pointed out in post #10 in the first place.
