Uncertainty principle and momentum
66 replies · 10K views
Maui said:
Why? What if the particle is detected at a classically forbidden portion on the detector screen? What kind of trajectory would that be? Zz seems to be talking of accelerated massive particles and this would be an important distinction.
Just an analogy, I'm not defending the use of a trajectory as conceptually correct.
I am fairly certain that a trajectory can be derived for massive particles and afaik Zz specializes in high energy physics(this is based mostly on his references on Tevatron etc, sorry if this is incorrect) so maybe we are talking past each other.
The particle "trajectories" are joint inaccurate measurements of position and momentum. You can measure position and momentum simultaneously, just not both accurately. For unbiased measurements (and maybe some other conditions), the uncertainty principle is the Arthurs-Kelly relation. There are other inequalities for joint or sequential measurements of non-commuting observables, eg. http://arxiv.org/abs/1304.2071 , http://arxiv.org/abs/1306.1565.
Sure, but massive particles behave semi-classically or almost classically because their momentum is very large and their wave behavior negligible(little x uncertainty due to lambda being very small). The uncertainty principle is not very useful for very massive particles is it?
Maui said:
I thought small slit size guarantees interference(for non massive particles) and a trajectory would be impossible to derive?
Of course, if the slit is too small, we will get single-slit interference, but I think the trick is to make it just small enough (not to get interference), and then utilize the distance between the slit and screen to "even out" uncertainty in position.
For instance; if we have a slit of 5 mm and 10 m between slit & screen, and fire photons (c) at the screen, maximal deviance in 'trajectories' will be 0.00125 mm, and at c this means a maximal 0.000004125 ns difference in travel time.
But... now I ask myself... what if we make the distance between slit & screen extremely large...?
Would that ever make a 'threat' to HUP?? :bugeye:
How large must it be to get close to [itex]\hbar / 2[/itex] ... ?
atyy said:
So do you retract the claim that position and momentum can be simultaneously measured with arbitrary accuracy?
ZapperZ said:
No, because this "accuracy" in a single measurement depends on the INSTRUMENT accuracy, not on the HUP! The "arbitrary" accuracy means that the accuracy of a momentum measurement and the accuracy of the position measurement are NOT COUPLED as in the HUP!
I still don't understand what you mean by a simultaneous accurate measurement of position and momentum are possible. Let's say we have the slit of width x, the state immediately after the slit is ψx, and this is the state on which you would like to have simultaneous accurate position and momentum information. By placing a screen in the far field you can accurately measure the momentum of ψx. If you wish to get better position information you must add a narrower slit of width y, and the state after the narrower slit is ψy, so that now the momentum distribution on the screen at large distance is that of ψy, which is an accurate measurement of momentum on the wrong state, since it is ψx whose momentum distribution we wanted to measure. So I don't see how changing position resolution does not change your momentum accuracy, since you don't have the same state any more on which to make your accurate momentum measurement. It is an accurate momentum measurement on the wrong state, which means it is inaccurate.
The usual way of demonstrating the "intrinsic" uncertainty principle, where position and momentum measurements are both accurate, is with separate, non-simultaneous measurements of position and momentum. In one set of experiments you measure position, and in a separate set of experiments you measure momentum. You don't measure position first then measure momentum. Since position and momentum are not measured simultaneously, they can each be arbitarily accurate.
Here perhaps is a derivation of ZapperZ's claim that the classical equations hold at near field. For a free particle or harmonic potential, the time evolution of the Wigner function is the same as the classical Liouville equation for a distribution in phase (p, x) space. The Wigner function in general is not a probability distribution because it can be negative. However, for a Gaussian wave function, the Wigner function is positive. Also the free time evolution preserves Gaussianity. Under these conditions, a particle does have simultaneously well defined position and momentum (really? If so indeed SURPRISE!). So if ZapperZ meant the initial wave function to be Gaussian, his claim may make sense.
As I understand it, the fact that the far field position distribution reflects the initial momentum distribution holds for arbitrary initial wave functions, even those with Wigner functions with negative bits.
