Uncertainty in Wavelength Calculation from Wave Crests on a Pier
The discussion centers on calculating the minimum uncertainty in wavelength from observing 15 wave crests on a 20-meter pier. Participants express confusion about applying quantum mechanics principles, particularly the uncertainty principle, to this problem. They debate the relationship between wavelength and uncertainty, noting that simply calculating the wavelength as 20m divided by 15 does not address uncertainty. Suggestions are made to consider the maximum and minimum possible wavelengths within the given constraints. Ultimately, the conversation highlights the challenge of linking classical wave observations with quantum uncertainty concepts.
Ryan Hardt
Standing in the middle of a 20 m long pier, you notice that at any given instant there are 15 wave crests between the two ends of the pier. Estimate the minimum uncertainty in the wavelength that could be computed from this information.
[/B]
Uncertainty Principles
ΔxΔp ≥ ħ/2
ΔEΔt ≥ ħ/2
I don't really understand how to use the equation to solve the problem. I am given no info on momentum or its uncertainty, and therefore cannot get any relation between the two. Perhaps I am not using the right equations? Any guidance twoards getting the right tools/solving it would be great as there are multiple problems of his ype that I am stuck on, I am fine with doing work myself.
[/B]
ΔxΔp ≥ ħ/2
ΔEΔt ≥ ħ/2
Are you sure this is Quantum Mechanics?
Yes, introduction to quantum. Maybe the problem is being overly simple on purpose (expecting the answer in terms of variables) as I'm quite confused.
Another example:
"The frequency of the alternating voltage produced at electrical generating stations is carefully maintained at 60.000 Hz. How often can the frequency be measured if the reading is to be accurate within 0.010 Hz?"
Perhaps this is a better example.
Another example:
Let's stick to the first problem Suppose you were sitting at the seaside and someone said:
That pier is ##20m## long and I can see ##15## wavecrests between the ends, so the wavelength must be ##1.33m##. What would you think?
Sure I can get a value for the wavelength, but that doesn't really tell me anything about its uncertainty, correct? As its minimum would only change depending on the uncertainty of another measurement with a set ratio related to ħ/2.My attempt at deriving the equation for wavelength uncertainty:
if Δp = h/Δλ
then ΔxΔp ≤ ħ/2
(hΔx)/(ħ/2) ≤ Δλ
4πΔx ≤ Δλ
But this doesn't seem useful as I don't have any info on positional uncertainty.
Do you think that's correct then? The wavelength must be exactly ##20m/15##? Leaving asside the HUP.
You can't see any flaw in that calculation?
Likes Jamison Lahman
Perhaps try thinking about it like this: What is the largest wavelength you can have with 15 waves in a 20m pier? What is the shortest?
  • · Replies 16 ·
9K
