Calculating Electron Energy with Uncertainty Principle: Homework Example
The discussion focuses on calculating the minimum energy of an electron confined to a spherical region of radius 0.1 nm using the uncertainty principle. The initial calculation yielded 2.86 eV, but the expected answer is approximately 10 eV. Key equations include the uncertainty relation (delta-x * delta-p = h-bar / lambda) and the energy formula (Energy = 0.5 * p^2 / m). The participants highlight the need to correctly account for the uncertainty in position and momentum, suggesting that the initial approach may have overlooked critical factors.
  • Understanding of the Heisenberg Uncertainty Principle
  • Familiarity with quantum mechanics concepts
  • Knowledge of electron properties (mass, charge)
  • Basic proficiency in mathematical physics
  • Review the Heisenberg Uncertainty Principle in detail
  • Study the derivation of energy levels in quantum confinement
  • Learn about the implications of spherical confinement on electron behavior
  • Explore statistical methods for deriving uncertainty principles
Students and educators in physics, particularly those studying quantum mechanics and the behavior of electrons in confined systems.
v_pino
Using the uncertainty principle, estimate the minimum energy in electron volts of an electron confined to a spherical region of radius 0.1nm.
delta-x * delta-p = h-bar / lamda
delta-y * delta-p = h-bar / lamda
delta-z * delta-p = h-bar / lamda
Energy = 0.5* p^2 / m
p = momentum
m = mass of electron
By letting the uncertainty in position (delta-x, delta-y, delta-z) equal to r, I got 2.86eV :
Total energy = 3/8 * (h-bar^2 / r^2 * m)
But the answer should be ~ 10ev.
[STRIKE]If the electron is confined in a spherical region, the uncertainty in X is given by \Delta X = X_{2} - X_{1}
So taking the centre of the sphere as 0, you will have 0.1nm and -0.1nm as X_{2} and X_{1} respectively, \DeltaX will then be 0.2nm
Hope this helps ;)[/STRIKE]
Mulling it over a coffee. Brb.
This will make matters worse by a factor of 4. Also on the right hand side of the uncertainty inequality there should be a 1/2, which would give an additional factor of 4 in the wrong direction. Are you sure the given answer is correct.
Sure, no. I'll consider over a coffee.
One can derive the general uncertainity principle by using the standard deviation method of statistics.
Here delta(x) and delta(p) are standard deviations.
(delta(x))^(2)=|<x^(2)>-<x>^(2)|
(delta(p))^(2)=|<p^(2)>-<p>^(2)|
So how does this help solving the problem at hand?
