Uncertainty Relation for Eigenstate of Spin-1/2 Particle
24 replies · 3K views
Robben
Calculate ##\triangle S_x## and ##\triangle S_y## for an eigenstate of ##\hat{S}_z## for a spin##-\frac12## particle. Check to see if the uncertainty relation ##\triangle S_x\triangle S_y\ge \hbar|\langle S_z\rangle|/2## is satisfied.
##S_x =\frac12(S_+ +S_-)##
##S_y = \frac{1}{2i}(S_+-S_-)##
I am not sure what I have to do in this problem. For the matrix representation I have that:
##S_x = \frac{\hbar}{2}\left[\begin{array}{ c c }0 & 1 \\1 & 0\end{array} \right]##
##S_y = \frac{\hbar}{2i}\left[\begin{array}{ c c }0 & -1 \\1 & 0\end{array} \right].##
on Phys.org
Orodruin said:
What is the definition of uncertainty? I suggest you start from that and see what you can find based on it.
I was more concerned on the first part of the question.
Orodruin said:
Yes? The uncertainty is ##\Delta S_x##, how is it defined? Later you can go on to the uncertainty relation, which as the name suggests is a relation of uncertainties.
Ops, I thought you were talking about the uncertainty relation. But regarding ##\triangle S_x## the uncertainty is defined as ##\sqrt{\langle S_x^2\rangle -\langle S_x\rangle^2}##, where ##S_x = \frac{\hbar}{2}P_1 -\frac{\hbar}{2}P_2##.
So all I do is do matrix multiplication with ##S_z##, i.e.
##(S_x) (S_z)=\frac{\hbar}{2}\left[\begin{array}{ c c }0 & 1 \\1 & 0\end{array} \right]
\left[\begin{array}{ c c }1 & 0 \\0 & -1\end{array} \right].##
To compute the expectation value of any operator ##\hat{\mathbb{O}}## for a particle in the state ##|\phi\rangle## is defined as ##\langle \hat{\mathbb{O}}\rangle = \langle \phi|\hat{\mathbb{O}}|\phi\rangle.## But what will the eigenstate for ##S_z## be?
Orodruin said:
I suggest you take one of the ones required by the problem statement, i.e., any of the eigenstates of ##S_z##.
That doesn't help me understand.
So let us try it this way: What are the eigenstates of ##S_z##?
Edit: Also, you should perhaps look for a different way of computing your expectation values. I suspect the one you quoted will not be very helpful. How would you compute ##P_1## and ##P_2## and how would you compute ##\left< S_x^2 \right>##?
Well, in the book it states that ##\hat{\mathbb{J}}_+|\lambda,m\rangle## is an eigenstate of ##\mathbb{J}_z## (where I was told that ##\mathbb{J}_z## and ##\mathbb{S}_z## are interchangeable)##.
So I can't use ##S_x = \frac{\hbar}{2}P_1 -\frac{\hbar}{2}P_2##? I do not know any other way of computing the expectation values other than that definition.
Yes, but it requires that you already are familiar with another eigenstate. Are you familiar with how to find the eigenvectors of a matrix?
Not unless you figure out how to comput ##P_1## and ##P_2##. What about the way you quoted in post #7?
Yes, I am familiar with how to find eigenvectors. In quantum mechanics, I have difficulty in setting up the problem correctly. Computing it, I can do but setting it up I need a lot more practice with.
Not unless you figure out how to compute ##P_1## and ##P_2##. What about the way you quoted in post #7?
That I know how to compute, its just that I am having trouble finding ##|\phi\rangle##. Since we have ##S_x##, i.e., ##
S_x = \frac{\hbar}{2}\left[\begin{array}{ c c }0 & 1 \\1 & 0\end{array} \right].## Thus, I need to compute ##\langle\phi|S_x|\phi\rangle##.
Orodruin said:
So, how do you represent ##S_z## in matrix form? What are the eigenvectors of that matrix? (The eigenvectors of the matrix represent the eigenstates.)
In matrix form ##
Orodruin said:
... and so the eigenvectors are ...
Will the eigenvectors just be ##|+z\rangle = {1\choose 0}## and ##|-z\rangle ={0 \choose 1}?##
Orodruin said:
You tell me. Is ##S_z |+z\rangle = \lambda_+ |+z\rangle## for some constant ##\lambda_+##?
Yup, it does satisfy that. I made this more difficult than it is. -__-. Thank you very much!
Orodruin said:
Just to resolve the problem itself: What do you get for ##\langle S_x\rangle## and ##\langle S_x^2 \rangle##, respectively? What is the resulting uncertainty relation?
Using ##\langle \hat{\mathbb{O}}\rangle = \langle \phi|\hat{\mathbb{O}}|\phi\rangle \implies \langle +z| S_x|+z\rangle.## Therefore, ##\langle S_x\rangle = 0##
Orodruin said:
Yes, this is correct. And ##S_z^2##?
##S_x^2## will also equal ##0## since , ##\langle S_x\rangle^2=0##.
No, ##S_x^2## is a different operator than ##S_x##. So you need to actually compute its uncertainty by itself.
Opps, thank you very much for catching that! It will equal ##\frac{\hbar^2}{4}## instead of ##0##.
