Understanding a Math Equation Step by Step
  • Thread starter Thread starter quicksilver123
    Math equation
16 replies · 3K views
quicksilver123
my book shows:
(-1/(1-((b+acosx)/(a+bcosx))^2)^1/2) * ((a+bcosx)(-asinx)-(b+acosx)(-bsinx))/(a+bcosx)^2
(a^2+b^2cos^2(x)-b^2-a^2cos^2(x))^(-1/2)
((a^2-b^2)sinx/(| a+bcosx |))
I'm having a hard time understanding how they did this.
Edited. Thanks for the heads up, "c" was a typo
quicksilver123 said:
my book shows:
It's really hard to read your equation. Do you know how to use LaTeX? There's a tutorial here: https://www.physicsforums.com/help/latexhelp/
But in the meantime, is this what you meant?
##\frac{-1}{\sqrt{1-(\frac{b+a\cos(x)}{a+b\cos(x)})^2}} \frac{(a+b\cos(x))(-a\sin(x))-(b+a\cos(x))(-b\sin(x))}{(a+b\cos(x))^2} = \frac{1}{\sqrt{a^2+b^2\cos^2(x)-b^2-a^2\cos^2(x)}} \frac{(a^2-b^2)\sin(x)}{|a+b\cos(x)|} ##
Admittedly that's quite tricky to format, brackets don't enclose the fraction and that type of thing, someone might have suggestions on how to improve on it.
Thanks!
Actually this is what I meant. I copy and pasted and edited your latex script.
Mod note: Changed from inline tex (## tags)to standalone tex ($$ tags) to make everything larger and easier to read.
$$\frac{-1}{\sqrt{1-(\frac{b+a\cos(x)}{a+b\cos(x)})^2}} \frac{(a+b\cos(x))(-a\sin(x))-(b+a\cos(x))(-b\sin(x))}{(a+b\cos(x))^2} = \frac{1}{\sqrt{a^2+b^2\cos^2(x)-b^2-a^2\cos(x)^2}} \frac{(a^2-b^2)sin(x)}{|a+bcos(x)|} $$Actually we have the same equation despite my edits haha. It just wasn't displaying correctly with my phone being vertical.
Anyway, that's what I need help with.
Thanks!
##\frac{-1}{\sqrt{1-(\frac{b+a\cos(x)}{a+b\cos(x)})^2}} \frac{(a+b\cos(x))(-a\sin(x))-(b+a\cos(x))(-b\sin(x))}{(a+b\cos(x))^2} = \frac{1}{\sqrt{a^2+b^2\cos^2(x)-b^2-a^2\cos(x)^2}} \frac{(a^2-b^2)sin(x)}{|a+bcos(x)|} ##Actually we have the same equation despite my edits haha. It just wasn't displaying correctly with my phone being vertical.
I would start with the left side to see if I end up with what's on the right. For starters, combine the two terms in the radical, and rewrite that whole factor in the form ##\frac{\sqrt{\text{something}}}{\sqrt{\text{something else}}}##.
Next expand the products in the numerator of the 2nd factor -- some of the terms will probably drop out.
$$\frac{-1}{{1-}\frac{\sqrt{b^{2}+2abcosx+a^{2}cos^{2}x}}{\sqrt{a^{2}+2abcosx+b^{2}cos^{2}x}}}\cdot \frac{-a^{2}sinx+b^{2}sinx}{a^{2}+2abcosx+b^{2}cos^{2}x}$$That's where I am. Obviously I can factor the a^2 and b^2 and the sin on the right numerator but uh... stuck.
Oh, and this handy little tool for latex previews: https://www.codecogs.com/latex/eqneditor.php
There'a a preview button here on the lower right.
How did you get this?
$$\frac{-1}{{1-}\frac{\sqrt{b^{2}+2abcosx+a^{2}cos^{2}x}}{\sqrt{a^{2}+2abcosx+b^{2}cos^{2}x}}}$$
You don't show the intermediate steps, but it looks like you did something like this: ##\sqrt{1 + x} = \sqrt{1} +\sqrt{x}##, which is incorrect.
In my previous post I said this:
In case I wasn't clear, I was talking about the radical in the denominator of the first factor on the left side.
That's just a typo. The entire fraction is meant to be under a square root.
Your answer here doesn't make sense to me.
Here's part of the left side, from post #5
$$\frac{-1}{\sqrt{1-(\frac{b+a\cos(x)}{a+b\cos(x)})^2}}$$
In post #7 you show this (again only showing part of the left side):
Is this what you really meant to write?
$$\frac{-1}{\sqrt{1 - \frac{\text{stuff}}{\text{other stuff}}}}$$
If so, what I said before was this -- inside that radical combine the 1 and the fraction into a single fraction. Don't keep it as a difference of two terms.
Yes that is what I wanted to write. Everything under the square root all at once.
Any help?
Any help?
What do you call this?
See the attached photo for my issue.
The fourth line up from the bottom looks OK, although there's no good reason to expand the ##(a + b\cos(x))^2## part in the denominator inside the radical.
You have a mistake in the third line up from the bottom. I didn't look at the other factor on the left side.
Also, you have something like this: $$\frac{-1}{\sqrt{\frac{xxx}{yyy}}}$$
This part could be simplified to this:
$$-\sqrt{\frac{yyy}{xxx}}$$
You don't need to expand so much stuff .
Consider: ##\ (a+b\cos(x))^2-(b+a\cos(x))^2 \ ##
That's a difference of squares thus: ##\ (a+b\cos(x)-(b+a\cos(x))\,)(a+b\cos(x)+b+a\cos(x)) \ ## .
With some rearranging: ##\ ((a-b) - (a-b)\cos(x))((a+b)+(a+b)\cos(x)) \ ##
##((a-b) (1-\cos(x))((a+b)(1+\cos(x)) \ ## and so forth.
In this case one gets a much simpler final answer by NOT using ##A^2-B^2 = (A-B)(A+B)##, but, instead, just expanding out ##A^2 =(a+b\,\cos x)^2## and ##B^2 = (b+a\,\cos x)^2## and cancelling some things.
