Understanding converting a vector field to cartesian coords
The discussion centers on converting a vector field to Cartesian coordinates, specifically addressing confusion over part B of a homework problem. The user seeks clarification on how the solution reached a Cartesian answer and the significance of the 36-degree angle, which is identified as 0.2π radians corresponding to the angle phi. Another participant explains that the solution involves calculating the components of a vector along unit vectors, leading to the appearance of the term 0.5 in two different contexts. Ultimately, the user resolves their confusion by applying the equations x = p*cos(phi) and y = p*sin(phi) to the original Cartesian equation. The conversation highlights the importance of understanding vector components and angle conversions in vector field problems.
shemer77
Here is the problem and solution but I am confused as to part B
http://gyazo.com/e77d05fc67cb6ac266ff021ef88052dc
I understand the first part, but I am totally lost on how they reached their cartesian answer for part B. Firstly why did they do what they did, and secondly where did 36 degrees come from?
I feel like their is some sort of equation or something I am not understanding.
36 degrees is 0.2π. It's the angle the gave you for phi. Does that help? Other than that they are just using that if u is a unit vector then the component of D along u is (D.u)u.
Hmm ok but why does he have .5 twice as in .5(ap.ax)ax +.5(ap.ax)ay?
One term finds the ax component of 0.5ap and the other finds the ay. Are you sure you understood the first part?
hmm okay thanks I think I figured it out. All I did was use the equations x = p*cosphi, y=p*sinphi and plugged those into the original equation which was already in cartesian for me.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
