Understanding Critical Numbers and Inflection Points in Calculus
  • Context: Undergrad
  • Thread starter Thread starter algorithmia
    Confusion Numbers
Critical numbers of a function are determined where the first derivative is zero or undefined, provided the function itself is defined at those points. Discontinuities in the original function can serve as critical numbers for determining concavity, but they are not considered extrema. The second derivative is used to find points of inflection, where the function changes concavity, and only the zeros of the second derivative are classified as inflection points if the function is defined at those locations. This distinction is crucial for accurately analyzing function behavior.
  • Understanding of first and second derivatives
  • Knowledge of critical points and extrema
  • Familiarity with concavity and inflection points
  • Basic graphing skills, particularly with trigonometric functions
  • Study the definition and properties of critical points in calculus
  • Learn how to find and interpret inflection points using the second derivative test
  • Explore the behavior of trigonometric functions, specifically the tangent and secant functions
  • Review continuity and differentiability in relation to function analysis
Students learning calculus, educators teaching mathematical concepts, and anyone seeking to deepen their understanding of critical numbers and inflection points in function analysis.
algorithmia
I am a bit confused over something that should be relatively easy to research , however, I am having a hard time finding a direct answer to my question.
When finding the extrema of a function , we find at what points the first derivative is 0 or undefined .. with the stipulation , if I am not mistaken , that the function itself IS defined at those values(continuous but not necessarily differentiable at those points) .. if they are not , then they will not be critical numbers per the definition . .
when finding concavity / points of inflection .. i am assuming the continuity requirement for the original function with respect to the critical numbers of the second derivative is dropped . am i right ? ..also , can I automatically assume if there are discontinuties in the original function , those will serve as critical numbers for sake of determining concavity ?
i am getting conflicting information but my intuition tells me this has to be so . just by looking at a couple graphs.concavity changes between vertical asymptotes. but i just wanted to make sure .. my book sucks. =D
Finding the critical points of a function means where the function's derivative is either zero or undefined. So when you get a set of critical points, you are solving for both where the derivative is 0 and/or undefined.
Take the tangent function for example, which has a vertical asymptote every pi/2 + pi*k where k is an integer. Solving for critical numbers, we would get sec(x)^2 = 0. Since the secant never equals 0, the tangent never has a horizontal tangent line. But the secant is undefined at pi/2 + pi*k, which gives us where the derivative is undefined, because of the vertical asymptotes. To be clear, these asymptotes are included in these critical numbers, but are not extrema.
To solve for inflection points, we take the second derivative. Thus, we have 2tanx(secx)^2 = 0. 2(secx)^2 will never be zero, so we cancel it out. tanx = 0 at pi/4 + pi*k. However, because of the secant, the second derivative is also undefined at pi/2 + pi*k, and the function changes concavity at both of these sets. So, to clarify: the second derivative's zeros and undefined values gives us where the concavity changes. But only the zeros are considered inflection points, because the function must be defined in order for an inflection point to exist.
Hope this helps.
  • · Replies 22 ·
