Understanding Fluid Flow and Stress in Two Dimensions with LaTex Tutorial
14 replies · 4K views · last reply
williamcarter
Printed problem statement showing the falling film velocity profile equation v_z = (rho g delta^2 / mu) [(y/delta) - (1/2)(y/delta)^2] cos beta, labelled equation (2), with a note about a different coordinate system in solution 2B.1.
0=viscous+gravitational+pressure
I saw in the solutions that pressure=0 in this case, but why?
I also knew that : accumulation= flow in - flow out+generation, why not use this one?
Textbook page on falling film flow: momentum balance giving d tau/dx = rho g cos(beta), momentum flux tau = -rho g delta cos(beta)(1 - x/delta), velocity profile integration and Eq. 2.2-18.
(their solution)
We are interested in getting the velocity profile.
I do not understand why they said at x=delta there is no momentum being transferred?is it because it is at the interface? how exactly is the fluid flowing?I want to understand the phenomena
Below I am attaching 2 of my sketches, in the solution says that viscous force acting on x surface(which is perpendicular to the plane, and in the z direction). How did they knew that?
Which of the below sketches I made are correct, no1 or no2.
How can we deduce how is it flowing, given that he gave us the boundaries y=0 as the wall and y=delta as the gas-liquid interface?
Handwritten-annotated slide titled Falling film problem: a fluid film flows down an inclined plane at angle theta, with unit vectors, an air interface labelled, gravity components g_x = g cos θ and g_y = g sin θ, and green marks indicating τ = 0 at the interface and a cube-shaped object.
Slide titled Falling film problem showing a fluid layer on an inclined plane at angle theta, with a gas region above labelled air and an interface, y = delta at the top and y = 0 at the wall, gravity components g cos theta and g sin theta, and a hand-drawn cube and red markings.
I would really appreciate it if you could also provide me a better sketch, if mine are wrong.
Thank you in advance.
I've looked over the problem statement, and I've looked over you questions, and I can help you. I would like to start out by your saying in your own words what you think is taking place here, including the physical mechanisms involved. Let me get you started.
We have a film of viscous liquid sliding down an inclined plane. (Your turn to continue).
The fluid is sliding down due to gravitational effect, no pressure is involved as P=Patm=0 at the interface.
I believe my sketch no1 is correct for this problem as the fluid is acting on the x surface(perpendicular to the plane) in the z direction(inclined).
Applying the boundary conditions we can conclude that the velocity=0 , near the wall where x(width of film)=0 .
At x=delta , there is no momentum generated due to the interface.
OK. You had indicated that you didn't understand why the momentum flux is zero at the free surface. Do you understand this now?
Thank you for your answer, I am not sure, all I can think about when x=delta at the interface is that momentum is not generated due to the width of the film, and that the film is going to that zone(interface).
Please correct me if I do mistakes/say stupid things.
I hate developments in which they use the "momentum flux" approach. It drives me crazy, and the mathematics are very counter intuitive. So with your permission, I'm going to try how to illustrate how much simpler it is to do all this in terms of stresses and force balances. Would that be OK?
Meanwhile:
At the free surface, since air is on the other side of the interface, what is the normal stress that the air exerts on the fluid beneath the interface? Since the viscosity of air is so low, what do you think the shear stress is that the air exerts on the fluid beneath the interface?
Meanwhile:
Thank you so much for your reply, it is much appreciated.
Yes, it is ok, no problem , I would be glad !
Regarding to the 2nd part, is the shear stress so low/negligible because the density of the gas is also very low,like the momentum transfer is low because low density of gas that cannot transfer momentum into fluid?
It's more the low viscosity than the low density, but, in any event, the shear stress exerted by the air on the free surface is zero. (You are aware that the shear stress is equal to the viscosity times the velocity gradient, right?)
Remember that, from now on, we are going to work with shear stress rather than momentum flux, right? In your course, did they teach you that the momentum flux is equivalent to the shear stress? Stress is a so much easier concept to visualize than momentum flux because we can all relate to force per unit area.
In our course we have transport by convection and the lecturer calls the flux JBconv=Concentration of B * Velocity= (B/Volume)*Velocity=q*v*v(for B=momentum)
and also JBdiffusion=Tauzx (zx is just an example on z surface in x direction)
OK. I'd like to go to a simpler approach, but, before I do, there are some preliminaries I'd like to introduce.
Consider the figure below. It shows a slab of the fluid situated between planes of constant x, at ##x## and ##x+\Delta x##.
Diagram of a fluid slab between two dashed planes at x + Δx (top) and x (bottom), with unit vector i_x pointing up out of the slab at the top and -i_x pointing down out of the slab at the bottom.
Also shown in the figure are two unit vectors, each pointing from inside the slab to outside the slab at its two boundaries. So at the top surface, the unit vector is pointing in the +x direction, and at the bottom surface, the unit vector is pointing in the - x direction.
Now I'm going to do something a little crazy. I am going to write down the following quantity: ##\tau_{zx}\mathbf{i_z}\mathbf{i_x}##. Note that it is z-x component of the stress tensor multiplied by two unit vectors, one in the z direction and the other in the x direction, respectively. Note that there is no mathematical operation (such as the cross product or the dot product) implied between the two unit vectors. So, as it stands, this expression has no obvious physical meaning. But look what happens when we dot this quantity with a unit vector in the +x direction (pointing out of the slab) in the following way:
$$(\tau_{zx}\mathbf{i_z}\mathbf{i_x})\centerdot \mathbf{i_x}=\tau_{zx}\mathbf{i_z}(\mathbf{i_x}\centerdot \mathbf{i_x})=+\tau_{zx}\mathbf{i_z}$$This is the shear stress that the fluid within the slab exerts on the fluid above it (including its correct direction). So, to get this stress, along with its correct direction, all we need to do is dot our crazy expression (involving the two juxtaposed unit vectors) with a unit vector pointing out of our slab. From Newton's 3rd law, the shear stress exerted by the fluid above the slab on the fluid within the slab is just ##-\tau_{zx}\mathbf{i_z}##.
Now, let's go to the bottom boundary and do the same thing, and see what we come up with. The unit vector pointing out of the slab at the bottom boundary of the slab is ##-\mathbf{i_x}##. Now, doing our new trick, we get: $$(\tau_{zx}\mathbf{i_z}\mathbf{i_x})\centerdot (\mathbf{-i_x})=\tau_{zx}\mathbf{i_z}(\mathbf{i_x}\centerdot (\mathbf{-i_x}))=-\tau_{zx}\mathbf{i_z}$$ This is the shear stress that the fluid within the slab exerts on the fluid below the bottom boundary (including its correct direction). So, to get this stress, along with its correct direction, all we need to do is again dot our crazy expression with a unit vector pointing out of our slab. From Newton's 3rd law, the shear stress exerted by the fluid below the slab on the fluid within the slab is just ##+\tau_{zx}\mathbf{i_z}##.
This is a foolproof way for getting the correct forces exerted by the fluid above and below the slab on the fluid within the slab, along with guaranteeing that the direction and sign of the forces are correct.
I'll stop here and let you digest this. Next will do a force balance on the slab in our problem, using this new trick to get the correct forces.
Questions?
I see that you "like" what I've shown so far. Does that mean that you have what you need now to understand the solution to your problem, or that you would like me to continue?
I understood that bit you wrote it , I would be more than glad if you can continue.
Free Body Diagram for Force Balance:
Free body diagram of a fluid slab between x and x + Δx, showing shear stress arrows [+τzx iz] at x, [−τzx iz] at x + Δx, gravity term ρg cos β iz, and length Δz.
The figure above shows the force balance on a slab of the fluid between x and ##x+\Delta x##, and z and ##\Delta z##. This is the basic free body diagram. The equation for the force balance is $$\rho g \cos {\beta}\mathbf{i_z}\Delta z\Delta x+[\tau_{zx}\mathbf{i_z}]_{x}\Delta z-[\tau_{zx}\mathbf{i_z}]_{x+\Delta x}\Delta z=0$$Dividing this equation by ##\Delta x\Delta z##, taking the limit of the resulting equation as ##\Delta x## approaches zero, and dotting the resulting equation with ##\mathbf{i_z}## yields: $$\frac{d\tau_{zx}}{dx}=\rho g \cos \beta$$
How does this work for you?
I would also like the generalize the trick I taught you in post #10 to show how the stress tensor can be used to get the force per unit area (stress vector) on a plane of arbitrary orientation within the fluid.
Thank you very much for your reply, I understood until now,I would be happy if you could continue.
In post #10, we examined an unusual quantity ##\tau_{zx}\mathbf{i_z}\mathbf{i_x}## and showed how it could be used to determine the force per unit area (stress) on a plane of constant x. In the present post, we will extend this approach to greater generality and start to show how it can be used to determine the stress on a plane of any arbitrary orientation within the fluid (as well as the momentum flux through that plane).
We begin by writing down not just a single term, but a sum of similar terms in 2D (x,z) as follows:
$$\pmb{\sigma}=p\mathbf{i_x}\mathbf{i_x}+p\mathbf{i_z}\mathbf{i_z}+\tau_{xx}\mathbf{i_x}\mathbf{i_x}+\tau_{xz}\mathbf{i_x}\mathbf{i_z}+\tau_{xz}\mathbf{i_z}\mathbf{i_x}+\tau_{zz}\mathbf{i_z}\mathbf{i_z}$$where p is the pressure and the tau's are the viscous stresses.
Now, I have a homework problem for you. Based on what was done in post #10, what do you get if you do ##\pmb{\sigma}## with a unit vector in the x direction, ##\pmb{i_x}##. That is $$\pmb{\sigma}\centerdot \pmb{i_x}=(p\mathbf{i_x}\mathbf{i_x}+p\mathbf{i_z}\mathbf{i_z}+\tau_{xx}\mathbf{i_x}\mathbf{i_x}+\tau_{xz}\mathbf{i_x}\mathbf{i_z}+\tau_{xz}\mathbf{i_z}\mathbf{i_x}+\tau_{zz}\mathbf{i_z}\mathbf{i_z})\centerdot \pmb{i_x}$$
Up to now, your equations have been extremely hard to read because you haven't used the LaTex app. To do this homework assignment properly, you are going to have to learn LaTex. Physics Forums offers a simple tutorial on LaTex. To get to the tutorial, click on the INFO drop down menu, and then click on LaTex tutorial.
