Understanding Gravitational Force and Solving Related Problems
9 replies · 2K views · last reply
Maged Saeed
Please look at the picture.
$$F=\frac{GMm}{d^2}$$
I'm stuck with this problem , because I cannot imagine it properly.
If I say that the mass m is in between the two masses , I cannot find d in the choices ,, Any help please!
Multiple-choice physics question: two particles of masses M and 4*M separated by distance D; find the distance from mass M where net gravitational force on mass m is zero. Options A) D/3, B) D/2, C) 3*D/4, D) 4*D/3, E) 2*D/3.
The prompt gives you that the two large masses are separated by D, and that the small mass is somewhere between them, meaning that you are being asked for "d" in terms of "D."
The mass in between would have a net gravitational force equal to :
$$\frac{GMm}{d^2}-\frac{G(4M)m}{(D-d)^2}$$
and that should be ZERO.
Then solving for d won't lead to one of the choices!
What equation are you solving?
The equation is of the net gravitational force acting on smaller mass which should be zero.
WRITE the equation.
Can you eliminate GMm? Yes. Do so.
Take things one step at a time, and they'll usually fall into place for you.
