Understanding Normal Force Direction in Leaning Ladder & Cable Beam Systems
5 replies · 5K views · last reply
terryds
I know that normal force is a reaction force.
http://www.sumoware.com/images/temp/xzhhpaacgkdktjna.png
In the leaning ladder problem, the normal force is perpendicular to the floor and the wall.
But, in the cable and beam problem, why isn't the normal force perpendicular to the wall ?
http://www.sumoware.com/images/temp/xzeanhxxmcalmnkn.png Hmm.. Then, I imagine what the system (cable and beam) will be without the wall.
I think that the beam will fall down.
And, because the beam touches the wall, the wall will exert a force back to the beam at right direction.
So, the normal force will have up and right direction.
But, I imagine the ladder problem.
But, Why the N1 doesn't have the upward direction ?
I think if there is no wall, then the ladder must fall and rotate counter-clockwise.
Please explain me how to determine the normal force direction.
A normal force is by definition normal to the surface. If there is nothing else holding the beam at its contact point, it will fall down. The "something else" can be a frictional force due to a rough surface (in which case the resultant force will not be normal to the wall) or that the beam has been attached to the wall.
Hmm..
So, the force in up direction on the hinge is the frictional force
And the force in right direction on the hinge is the normal force
The resultant is the frictonal force + the normal force
Do I get this right?
And, if the beam is attached to the wall, is there any normal force ?
If you have a hinge, it is a completely different situation. There is a normal force from the hinge, but the hinge contact point is not tilted in the same direction as the wall. It is therefore misleading to talk about it as a normal force to the wall.
Free-body diagram of a horizontal beam hinged to a vertical wall at the left, supported by a diagonal cable from the wall to the beam's right end, with hinge force components F_Hx and F_Hy, cable tension T, cable components T_x and T_y, weight m g at the middle and load M g at the right end.
From the picture above, I have no idea about 'not tilted in the same direction as the wall'.
Then, how to know that the normal force is up and right in direction ?
What will the condition be if the normal force is down and right, or down and left, or etc ?
You do not, you can guess it (based on the other forces present) and define your force components in such a way, but you will not know for sure until you do the equilibrium analysis and find out what the components of the force are. The condition is that the beam is in equilibrium and the rest should follow from there.
