Understanding Potential Energy Graphs for Two-Particle Systems
10 replies · 3K views · last reply
AsadaShino92
The potential energy V(R) of a two particle system exhibiting oscillatory behavior near a local minimum at the equilibrium separation Ro. V(R)= -(A/R)+(B/R^2) , where R is the interparticle separation.
A) Sketch V(R), what happens to V(R) as R→0
B) At what value of R is there a minima in the potential?
C) For very small oscillations about this equilibrium point, Ro, write the force on the particle F=-k(R-Ro), define k.
I must apologize in advance because I feel that I'm about to ask a stupid question. But how can I plot this function if I don't know what the values of A and B are?
It's a good question.
What if you plot ##V## in units of ##A^2/B## and ##R## in units of ##B/A##?
[Edited to correct a mistake.]
Sorry, I'm not sure how I would plot the function in those terms such as A^2/B and B/A. Do you think I can fix the values like PeroK suggested? My only concern is that the function slightly changes based on what A and B are. But I see that the function runs off to infinity as R approaches 0.
Yes, you can go with PeroK's suggestion. The graph will be the same as I was suggesting.
Note that ##A^2/B## has the dimension of energy and ##B/A## has the dimension of length.
So, you can introduce dimensionless quantities ##\tilde{V} = \frac{V}{A^2/B}## and ##\tilde{R} = \frac{R}{B/A}##.
If you write the equation in terms of these dimensionless quantities ##\tilde{V}## and ##\tilde{R}##, you should find that ##A## and ##B## disappear.
Graphing ##\tilde{V}## versus ##\tilde{R}## will give the same graph as graphing ##V## versus ##R## with ##A= B = 1##.
Thanks for your explanation. I wasn't used to this method so I couldn't see the relationship before. For part B where it asks to find the minimum, taking A=B=1, I found an equilibrium point at R=1. Would it be correct for me to use the first derivative test?
For A = B = 1, I don't think the equilibrium is at R = 1. But, I'm pretty sure that you are meant to express the equilibrium value of R in terms of A and B.
Yes, use differentiation to find the minimum.
So then the equilibrium value of R is at R=(B/A)? I found this by leaving A and B as variables and setting V(R)=0.
The equilibrium condition is not V(R) = 0. Equilibrium is where the force is zero.
Since V(R) is given as the potential energy function in the problem, I can find my force function by using F(x)=-du/dx. Is that the right idea?
Yes. Good.
