Understanding Simple Harmonic Motion: Explaining x=Acos(wt+phi)
17 replies · 5K views
Jozefina Gramatikova
x=Acos(wt+phi)
can somebody explain to me please when phi=0. I saw many different questions with many solutions and I can't understand when we have just x=Acos(wt) and when x=Acos(wt+phi)
Jozefin Gramatikova said:
x=Acos(wt+phi)
It depends where the system starts at ##t=0##.
So, if it starts from x=0 at t=0 => phi=0? and at t=0 x=1 => phi would be different from zero?
So, if it starts from x=0 at t=0 phi=0? and at t=0 x=1 phi would be different from zero?
Yes. ##-A \le x(0) \le A##, where ##x(0)## is the displacement of the system at ##t=0##, and determines ##\phi##.
vela said:
Plug t=0 and ##\phi=0## into ##x(t) = A\cos(\omega t + \phi)##. Is ##x(0)## equal to 0?
x(t)=Acos(0)
x(t)=A
I don't know I am really confused right now.
PeroK said:
##\cos(0) = 1##
I know that :D Thats why I said:
"x(t)=Acos(0)
x(t)=A"
haruspex said:
Just substitute those t and x values in the general equation in post #8.
x=Acos(ωt+φ)
x0=Acos(ω x 0+φ)
x0=Acos(ω x 0+φ)
x0=Acos(φ)?
Could you give me the right solution, please? I get more and more confused with every single post.
Let's assume that ##A>0##, so when ##x(t) = A \cos( \omega t + \phi)##, the value of ##x(t)## oscillates back and forth between ##-A## and ##+A##. That is, ##-A \leq x(t) \leq A## for all ##t##. Furthermore, we have ##x = -A## for some ##t## and ##x = +A## for some other ##t##.
If ##\phi = 0## we have ##x(0) = A##, so that means that the motion starts at time zero from the upper end of the allowed interval. Then for a while ##x(t)## will decrease until it hits the lower end ##-A## of the allowed interval, at time ##\pi/\omega##. Then it will start to increase until it hits ##x=A## at time ##2 \pi/\omega,## etc., etc.
If you want ##x(0)## to be a point other than ##A## you need to have ##\phi \neq 0.## To help you to enhance your understanding, try the following question: "what would be the value of ##\phi## if you require ##x(0) = 0?## (Of course, because the ##\cos## function is periodic there will be many values of ##\phi## that will work, but among these there is one that is "simplest", and that is the one you should attempt to find.)
