Understanding Stresses and Neutral Axis in Structural Design
  • Thread starter Thread starter VooDoo
    Axis Neutral
3 replies · 4K views · last reply
VooDoo
Hey guys,
A picture of the question is attached, I am not seeking answers just an explanation of some theory.
Now I understand that
point A will be under compression due to the weight, tension due to the bending and shear due to torque produced by the wind
point b will be under compression due to weight, tension due to bending (but different tension to point A because of the different moment) and shear due to torque produced by the wind
point C will be under compression due to weight and compression due to bending and shear due to torque produced by the wind
Now when applying the bending stress equation (MY/I) wouldn't either point B and C together or point A on its own lie on the neutral axis? And hence the bending stress would be zero Or would Y (distance from the neutral axis) always be 50mm?
http://img23.imageshack.us/img23/5238/1233333333.th.jpg
VooDoo: If the top edge of the sign is parallel to the y axis, and the x-axis is vertical, then points B and C lie on the neutral axis for moment My, and point A lies on the neutral axis for moment Mz.
If the wind is blowing into the sign (into the page/screen), the A will be under tension. The force would apply a torque about the axis through BC. If the wind blows out of the scree/page, then A would be under compression.
One has to look at the distance a point is from the axis of rotation, and the torque applied with respect to that axis.
The post and sign apply a downward load on the base. Torques apply a tension or compression depending on whether they rotate away from or toward a point.
The base is a cantilever joint.
