Understanding Taylor Series: Finding the General Formula | Math Explained"
The discussion revolves around the Taylor series and its general formula, exploring its implications and the conditions under which it holds. Participants examine the relationship between different values of the expansion point \( a \) and the variable \( x \), questioning how these affect the function \( f(t) \) and the validity of the series representation.
  • Some participants question whether the Taylor expansion gives the same result for all values of \( a \), noting that it seems to imply \( f(1 + x) = f(4 + x) = f(\pi + x) \).
  • Others clarify that while the Taylor series can be expressed for different \( a_1 \) and \( a_2 \), this does not mean that \( f(a_1 + x) = f(a_2 + x) \) due to the potential differences in derivatives \( f^{(k)}(a_1) \) and \( f^{(k)}(a_2) \).
  • It is suggested that the variable \( x \) must change for \( t \) to remain well-defined when \( a \) changes.
  • Some participants express uncertainty about the implications of changing \( a \) and \( x \) and whether swapping their positions in the expansion would yield the same result.
  • A later reply introduces a philosophical perspective on the precision of mathematical language, emphasizing the importance of distinguishing between variables and constants in mathematical statements.
Participants express differing views on the implications of changing \( a \) and \( x \) in the Taylor series. There is no consensus on whether swapping these variables would yield the same result, indicating ongoing debate and exploration of the topic.
Participants highlight the need for careful consideration of variable definitions and scopes when discussing mathematical statements, particularly in relation to Taylor's Theorem and its applications.
PFuser1232
$$f(a + x) = \sum_{k=0}^∞ \frac{f^{(k)}(a) x^k}{k!}$$
Usually written as:
$$f(t) = \sum_{k=0}^∞ \frac{f^{(k)}(a) (t-a)^k}{k!}$$
Where ##t = a + x##
Is the taylor expansion supposed to give the same result for all ##a##? The reason this confuses me is because this seems to suggest that ##f(1 + x) = f(4 + x) = f(π + x)## and so on, which is usually not the case. Where did I go wrong?
Yes, in the sense that for a given [itex]t[/itex]
[itex]f(t) = \sum_{k=0}^\infty \frac{f^{(k)}(a_1) (t-a_1)^k}{k!} = \sum_{k=0}^\infty \frac{f^{(k)}(a_2)(t-a_2)^k}{k!}[/itex]
when both series converge.
In the first version you listed for Taylor series, to say that the equation holds for different [itex]a_1, a_2[/itex] does not imply [itex]f(a_1 + x) = f(a_2 + x)[/itex] since, in general, [itex]f^{(k)}(a_1) \ne f^{(k)}(a_2)[/itex]. In the second version you listed, different values of [itex]a_1, a_2[/itex] do not imply different values of [itex]t[/itex].
So the variable ##x## must also change for ##t## to remain well-defined.
The meaning of that statement isn't entirely clear, but I'm tempted to say yes.
In order to maintain the same meaning of ##t## (and ##f(t)##) while changing the value of ##a##, we must change the value of ##x##.
Yes, if we assert [itex]t = a + x[/itex].
If we were to swap the positions of all ##a##'s and ##x##'s in the expansion; that is: ##f(x) + f'(x)a + \frac{f''(x)a^2}{2!} + ...##, would we get the same result? I understand that our goal is to write a power series where the powers are constantly increasing on a variable, not a constant. But I'm curious, would this give the same result?
A logician could object to calling such a change in the formula "the same result" since logician wants it made clear which symbols are variables (in some scope) and which are constants (in some scope). Technically, a symbol like "x", should appear with the scope of a quantifier (like "for each") when we write a mathematical statement. People who do calculus are careful about quantifying their variables when they do epsilon-delta proofs (e.g. for each epsilon > 0, there exists a delta ...such that...), but in other aspects of calculus they are careless. You can talk about "Taylor's Formula" as a string of symbols. To ask a precise mathematical question about its meaning you need to first state "Taylor's Theorem" as a theorem. See which quantifiers apply to which variables. Then you can ask whether the symbols representing the variables can be swapped.
(a_n)_1^infty
({a_n})_1^ \infty
  • · Replies 16 ·
