Understanding the Difference Between pdV and Vdp
  • Thread starter Thread starter pivoxa15
    Difference
8 replies · 9K views
pivoxa15
The books often always present pdV but never Vdp. Why is that? surely it is present in expressions like dE or dG where G is the grand potential. Is it because we don't treat p as a variable? If so why not? For each of these function we can only have 3 variables? So having V and p both as variables would be a bit redundant? If so why?
In a grand canonical ensemble is pressure constant for any system? Hence dp=0? The grand potential doesn't appear to have dp in it.
Is it also because P is a state function so dP can always be expressed as other variables just like dU can. However temperture is also a state function? but it is treated as a variable.
They mention VdP. VdP is related to the change in internal energy of the gas at constant volume. PdV is the work done by/on the gas. Together, VdP + PdV = nRdT. Since nCvdT is the heat flow at constant volume and nCpdT is the heat flow at constant pressure, and Cp-Cv = R, VdP + PdV = nRdT = n(Cp-Cv)dT
AM
Why don't they have Vdp in the expression of the grand potential?
G = grand potential = -pV
So dG = -pdV - Vdp = -SdT -pdV - Ndu
So -Vdp = -SdT - Ndu?
or Vdp = SdT + Ndu which must be true by definition would it? It's more convineint to use the right hand side instead of the left hand side?
Careful.
dQ = TdS
dU = nCvdT
dW = PdV
So the first law dQ = dU + dW can be written:
(1) TdS = nCvdT + PdV
Since d(PV) = VdP + PdV = d(nRT) = nRdT,
PdV = nRdT - VdP
So substituting this for PdV in (1):
(2) TdS = nCvdT + nRdT - VdP
(3) VdP = nCvdT + nRdT - TdS = nCpdT - TdS = nCpdT - dQ
So the first law can be written:
(4) dQ = nCpdT - VdP
AM
You haven't disproved Vdp = SdT + Ndu have you?
I am not sure what you mean by Ndu. I think it refers to added molecules.
From the Euler equation:
U = TS - PV
dU = d(TS) - d(PV) = (TdS + SdT) - (VdP + Pdv)
But the first law states that dU = dQ - PdV. Since dQ = TdS:
dU = TdS - PdV so
SdT - VdP = 0
AM
u stands for the chemical potential constant. If you have dU=dQ-Pdv you have not accounted for the chemical potential of particles entering and leaving the system. If you did then dU=TdS-pdV+udN. So
We have
U = TS - PV + uN
dU = d(TS) - d(PV) + d(uN)= (TdS + SdT) - (VdP + Pdv) + (Ndu + udN)
We have
dU=TdS-pdV+udN
So SdT - Vdp + Ndu = 0
hence Vdp = SdT + Ndu
Although why is U = TS - PV + uN?
Or even why is U = TS - PV when not accounting for chemical potential?
Is it more the fact that we first know the expressions for dU then work out U from those expressions?
