phillip_at_work
- 13
- 2
- Homework Statement
- Given the triplet prescription as illustrated in Figure 5.17... find a) the size and location (relative to stop) of the entrance pupil using paraxial ray trace equations (PRTE); b) the starting heights and angles on surface 1 for the marginal and chief rays, again using PRTE [Problem statement attached]
- Relevant Equations
- y_f = y_i + u' * t
n' * u' = n * u - y * phi
(typical paraxial ray trace equations)
Per the description given in the book, one can trace rays FROM the physical aperture stop into object space to find the size and location of the entrance pupil (EP). Also, one can trace rays FROM the physical aperture stop into image space to find the size and location of the exit pupil (XP). In both cases, the EP and XP are images and the physical stop is the object to be imaged.
I implemented this ray trace using an Excel spread sheet (part a). This is attached in original Excel and also as a PDF.
To solve part b, I add the EP and XP into a second Excel ray trace. As I understand it, when I aim my system marginal ray at the rim of the EP, it should also travel through the rim of the physical stop and the rim of the XP as shown on slide 10-29 of Greivenkamp's thin lens EP/XP ray trace here: https://wp.optics.arizona.edu/jgrei...es/11/2018/12/201-202-10-Stops-and-Pupils.pdf
At the moment, I'm doing this using an object at an arbitrary distance (80mm) and of arbitrary height (10mm), since the pupil locations shouldn't depend on this (also per Greivenkamp).
However, aiming my marginal ray at the rim of the EP does not show that ray touching the rim of the stop and XP. So I suppose I've either traced the EP and XP incorrectly (part a) or I'm implementing the EP and XP incorrectly in the second ray trace (part b).
Any feedback is much appreciated.
