Understanding the Role of Latent Heat Energy Transport in Climate Change
The discussion centers on the role of latent heat energy transport in climate change, particularly how evaporation and condensation processes influence the radiation balance and feedback mechanisms in the atmosphere. Participants explore the implications of changing relative humidity and absolute humidity in the context of increasing greenhouse gas concentrations and surface temperatures.
  • Some participants propose that latent heat transport from evaporation to condensation significantly alters the dynamic radiation balance, especially in the context of global warming.
  • Others argue that the assumption of constant relative humidity under increasing temperatures may not hold, raising questions about the energy required to maintain this assumption.
  • A participant suggests performing back-of-the-envelope calculations to estimate the order of magnitude of evaporation and its energy implications.
  • It is noted that convection plays a crucial role in heat transport, and changes in convection rates could affect absolute humidity without necessarily increasing heat input.
  • Some participants discuss the relationship between absolute humidity and temperature, referencing the Clausius-Clapeyron equation to explain how higher temperatures lead to increased partial pressures of water vapor.
  • There is a suggestion to investigate how absolute and relative humidity change with temperature, with preliminary calculations indicating a 6% increase in water vapor per degree of temperature rise to maintain relative humidity.
  • Concerns are raised about the assumption that convection will remain constant, with some suggesting that increased heat content in the air could lead to less effort required for convection.
Participants express multiple competing views regarding the assumptions of constant relative humidity and the effects of temperature on humidity and convection. The discussion remains unresolved, with no consensus reached on the implications of these factors for climate modeling.
Limitations include the dependence on assumptions about humidity behavior under varying temperatures and the complexity of interactions between convection and latent heat transport. The discussion also highlights the challenge of quantifying these effects accurately in climate models.
  • #61
Andre said:
But it is an assumption, right? maintaining relative humidity constant with increased greenhouse effect, without any visible justification in the decription of all the processes as we attempted here. So one could argue about it being a reasonable assumption seeing the considerable energy required for excess evaporation and because the observations don't appear to confirm the assumptions.
You seem to stick to this "considerable energy required" and "excess evaporation" which I argued all the time, doesn't have anything to do with it.
With lower hadley cell turnover velocities, you can have higher humidities together with less evaporation and hence less required energy for evaporation. However, with higher horizontal mixing you might get lower or higher relative humidities and higher rates of evaporation. As the hadley cell turnover velocity will adapt to the required heat transport, there will never be "lack of energy for evaporation": if any lack is there, the hadley cell turnover will slow down.
You could get higher relative humidities, or lower relative humidities, depending on how mixing of dry and wet air will change as compared to now, and this without putting any burden on "energy required" or even on "evaporation required" and the only way to really find out is to do a very detailed simulation.
I'm not saying that there is any proof that relative humidities will remain constant, just that it is a very sensible assumption if you don't know any better, much more so than assuming that absolute humidities will remain constant, as if "nothing else changes" (although it probably will), the humidities are mainly given by the ocean (and "wet" land) temperatures AND how they mix together with "dry air". If the mixing is done in the same way, and the temperature rises, then there's no reason not to assume that the relative humidities will remain the same (one will mix together 100% wet air with dry air in the same proportions, and the "100% wet air" is determined by the temperature of the water reservoir with which it was in contact). This is NOT fixing any "evaporation rate", as this evaporation rate is determined also by the VELOCITY of the turnover, and this velocity is something that will adapt to whatever heat that has to be transported in order to get the lapse rate close to the adiabatic lapse rate. As this velocity can hence change, the evaporation rate can also change, with given humidities.
In fact, it would be rather difficult to keep "absolute" humidities constant, while having warmer water. Warmer water will normally lead to higher absolute humidities because the evaporation drive is greater in that case.
  • #62
I am merely sticking to the requirement that assumptions would need some validation while Lindzen and Choi (2009) demonstrate that there is no such a validation.
Edit: and while we are at that, maybe that http://www.agu.org/pubs/crossref/2008/2008JD010064.shtml also hints into the same direction:
Rondanelli, R., and R. S. Lindzen (2008), Observed variations in convective precipitation fraction and stratiform area with sea surface temperature, J. Geophys. Res., 113, D16119, doi:10.1029/2008JD010064.
...We find that the fraction of convective precipitation increases with Sea Surface Temperature (SST) at a rate of about 6 to 12%/K and the area of stratiform rainfall normalized by total precipitation decreases with SST at rates between −5 and −28%/K. These relations are observed to hold for different regions over the tropical oceans and also for different periods of time. Correlations are robust to outliers and to undersampled precipitation regions. ...
  • #63
Andre,
can you indicate what this is supposed to mean in the context of what we are discussing here (namely, whether there is not enough power to raise absolute humidity to levels that keep relative humidity constant) ?
What does this observation of precipitation have to do with what is supposed to happen when we increase CO2 levels on humidity ?
Maybe it is explained in the article but I only have access to the abstract of that paper.
  • #64
Thanks for the Lindzen/Choi pointer.
I don't follow how that paper relates to this discussion - it addresses radiation (claims mistaken assumptions about radiation). Even if all the models are wrong per Lindzen/Choi, so what per this discussion? Edit: I see Vanesch beat me to the question.
  • #65
Both questions are not the same, but Lindzen and Choi are the core matter where, with the thread trying to hint what they may be seeing, with the big question being the dominance of positive or negative feedback on climate sensitivity.
The leading idea is that positive feedback prevails in climate sensitivity, one of the main factors being enhanced greenhouse effect of more water vapor at higher temperature, under the premisse that relative humidity remains constant.
Here I have tried to argue that maintaining relative humidity may require a lot of additional energy to enhance evaporation to sustain it, with the hadley cell as mechanism to show the open -air conditioner- function, transport of (latent heat) energy aloft for easier out radiation. This would act as a big negative feedback element, consuming the energy that was thought to go into heating. I wondered if the models did account for this energy as I see no evidence for that in the model descriptions, only that relative humidity is kept constant.
But there are many factors modifying and influencing effects, therefore I suggested to look at the end result. What are the measured effects of feedback? Positive or negative feedback? That answer is given by Lindzen and Choi 2009.
I'll attempt to get into the second publication tomorrow.
  • #66
Alright, but I don't think it is logical to point from your relative humidity discussion to Lindzen Choi as a basis. Rather, if Lindzen Choi are correct then perhaps some other negative feedbacks are at work (and unidentified by them), even so they are simply suggesting: go look for them.
  • #67
What I don't understand in the (other) Lindzen article is that they try to establish feedback effects on a time scale of the order of a year (that's what they do when they analyse the correlations over time periods of this order in time) I thought the eventual positive feedbacks were over several decades, so I don't see how their very short term correlations can say anything about climatological trends. At most they say that climate models are bad weather forcasters over 6 months or a year.
In as much as their comparison with climate models is correct, they do establish that *those* climate models don't make correct predictions on that short term. But honestly, I'm not really surprised at that, as climate models are supposed to model climate, which is an average over several decades, no ?
I don't think people "think" that this is going into heating in the first place. It is what I tried to argue here all along: if you take it that convection tries to establish the adiabat, and you take it that that adiabat is established by convection you take already this cooling into account. I'm NOT saying that this convection, and that this evaporation is not giving rise to a serious cooling, I'm saying that you already include it when putting down the adiabat. It is clear to everybody that convection is a powerful heat transport mechanism - it is the principal mechanism of heat transport in the lower troposphere.
The whole question is what will happen to humidity, and there I think if you really want to know, you need to do very detailed modeling, but that the best "first guess" is indeed keeping relative humidity constant. As the adiabat already takes into account all the heat loss by evaporation and all that, there won't be any problem with "not enough power to evaporate the water" by assuming constant relative humidity, because this is already included.
Because the adiabatic lapse rate *already* takes this into account!
  • #68
Two things.
  1. Emission is the primary feedback.
  2. Evaporation is only half of the water cycle.
When it gets warmer there is an instantaneous increase in emission, negative feedback.
Unless precipitation increases there is no need for a dramatic increase in evaporation to maintain relative humidity.
  • #69
vanesch said:
In a way, Andre is right of course that as convection will adapt, this will change winds, convection patterns, and so on, and this will have an influence on humidity and evaporation - only, it is not clear how much and in what sense without a deeper investigation. There could be more or less humidity. But it will never be because 'power is lacking'.
bumbing because I stumbled upon http://www.sciencemag.org/cgi/content/abstract/317/5835/233
...However, the climate models predict that global precipitation will increase at a much slower rate of 1 to 3% per kelvin.
Maybe because indeed consideration was given to the additional energy required to evaporate additional water
... the observations suggest that precipitation and total atmospheric water have increased at about the same rate over the past two decades...
Since precipitation removes water from the atmosphere, it seems that evaporation has to increase to the same rate/flux to maintain dynamic equilibrium. It seems that this was exactly the dispute between Vanesch and me.
And as I was trying to demonstrate, the increase in evaporation requires more energy than increased greenhouse effect from increased CO2 levels could bring, this effect would work as a dominant negative feedback.
It also suggests that a part of the required increase in precipitation would require another energy source for evaporation.
  • · Replies 28 ·
  • · Replies 36 ·
13K
