namanjain
- 70
- 0
F(external)=ma
mg-N=ma
direction of a downward
or if
a is upwards
N-mg=ma
N=mg+ma
mg-N=ma
or if
a is upwards
N-mg=ma
N=mg+ma
The discussion revolves around the apparent weight of an object in an accelerating elevator, focusing on the signs of gravitational acceleration (g) and the system's acceleration (a). Participants explore the implications of these signs in the context of free body diagrams and the normal force experienced by a person standing on a scale in an elevator. The scope includes conceptual reasoning and technical clarification regarding the application of forces in a non-inertial reference frame.
Participants express differing views on the sign conventions for acceleration and gravitational force, with no consensus reached on the correct interpretation of these signs in the context of the problem. The discussion remains unresolved regarding the relationship between the signs of g and a.
Participants highlight the importance of sign conventions and the assumptions made in free body diagrams, indicating that the discussion is dependent on these definitions and may vary based on individual interpretations.
Yeah, that was how I saw it already in the first post. However, it still doesn't explain my question since the first post.Doc Al said:Did your book not derive it? The derivation is just an application of Newton's 2nd law. Reread my previous posts for a derivation.
If you insist, then apply Newton's 2nd law as a vector equation. It's the same derivation:
∑F = mg + Fn
Set that equal to ma:
mg + Fn = ma
Done!
Rephrase your question then. (As I think I've answered it.)Maxo said:Yeah, that was how I saw it already in the first post. However, it still doesn't explain my question since the first post.
Maxo said:What is it then?
And how can the equation FN = mg + ma be made from the free body diagram if ma doesn't appear on it?
Obviously, two vectors pointing in the same direction will have the same sign when expressed as components.Maxo said:It seems my question is misunderstood. I understand all this that you write. That's not what I'm asking about. I understand this equation, how it's derived and why. I will try to reformulate it. Please hear my explanation:
What I am trying to find is some way to make so the following criteria is satisfied:
Two vectors pointing in the same direction should have the same sign.
g is a vector; g is not. Expressed in terms of components, the value of g is -g = -9.8 m/s^2. (Taking up as positive, of course.)The two vectors I'm talking about here are g and a.
Example. 100 kg on scale in elevator that acclerates downwards from rest. Scale shows 500 N. How large is the acceleration? Answer is 500/100-9.8 = -4.8 m/s2. Both g and a point in the same direction (downwards). But
g = 9.8 m/s2
a = -4.8 m/s2
You need to review how the equation you posted in your first post is derived.Here's the thing: Both g and a point in the same direction (downwards). BUT THEY DON'T HAVE THE SAME SIGN.
I want it to be so that same direction = SAME SIGN. So the question is: How can a new equation be derived that satisifies this criteria?
Maxo said:Two vectors pointing in the same direction should have the same sign.
No they don't. If they pointed in the same direction, scale would read more than 100 x 9.81 = 981N.Example. 100 kg on scale in elevator that acclerates downwards from rest. Scale shows 500 N. How large is the acceleration? Answer is 500/100-9.8 = -4.8 m/s2. Both g and a point in the same direction (downwards). But
g = 9.8 m/s2
a = -4.8 m/s2
Uh I made a blander here. What I wanted to say is that if your result was correct, the scale would read more than 981N.xAxis said:No they don't. If they pointed in the same direction, scale would read more than 100 x 9.81 = 981N.
xAxis said:Maxo, in both your original and reformulated question you made the same mistake, and it obviously comes from confusion about signs. If you want to declare g as a vector, no problem. But if you say that downwards direction is positive, g is acceleration, so all downward accelerations will be positive, and upwards negative. This doesn't mean that if lift moves downwards the acceleration is positive.
Just knowing the scale reading and mass, you can resolve the sign of acceleration a. You can't however tell if the elevator is moving up or down.
It may be moving, for example, downwards but decelerating or moving up and accelerating. In both cases the acceleration a will be of the same sign and magnitude.
And all this is anambiguously derived from second Newton's Law.
Maxo said:In my physics book the equation for apparent weight is given as
FN = mg + ma
You really should start using different symbols for the component of the vector and the magnitude of the vector. Let's say the Z-Axis of the coordinate system is up:Maxo said:You say there is no problem declaring g as a vector. Then I don't understand why when doing that and considering downwards a negative direction, why g is not negative?
A.T. said:You really should start using different symbols for the component of the vector and the magnitude of the vector. Let's say the Z-Axis of the coordinate system is up:
g = 9.81
\vec{g} = (0, 0, -9.81)
Or since it is only 1D:
\vec{g} = -9.81
Note that he says g = 9.81, not g = -9.81.Maxo said:Great, that's how I see it aswell!
Could you then please explain why using \vec{g} = -9.81 in the equation \vec{F_{N}} = m\vec{g} + m\vec{a} will give a POSITIVE sign for \vec{a} (i.e. which would correspond to positive/upwards direction), when the elevator accelerates DOWNWARD from rest (i.e. \vec{a} should also pointing in the negative/downwards direction, i.e. have a negative sign)?
Doc Al said:Note that he says g = 9.81, not g = -9.81.
For one thing, this vector equation \vec{F_{N}} = m\vec{g} + m\vec{a} is not valid. Per Newton's 2nd law, it should be:
\vec{F_{N}} + m\vec{g} = m\vec{a}
Maxo said:Finally! This equation makes sense! Why didn't you just write this in the first place? ;)
To me, this way of writing is more logical. I think vector notation is more clear.
Thanks for your help and patience.
Again, you can treat g a vector but it has to be constant. Once you decide on sign convention then g's sign is determined. Makes no sense to ask question why g is not negative. It simply is.Maxo said:...
You didn't use vector notation, which was what I was looking for. Maybe I didn't manage to express clearly what I was looking for, so you don't have to feel bad for misunderstanding. You were apparently not the only one.ZapperZ said:I don't get it.
I said way earlier that all the forces should be on one side of the equation, and the resultant dynamics (ma) should be on the other side of the equation.
And it took 46 posts for this to finally sink in?
Zz.
xAxis said:Again, you can treat g a vector but it has to be constant. Once you decide on sign convention then g's sign is determined. Makes no sense to ask question why g is not negative. It simply is.
You use 2nd Newton's to calculate ma.
And you always add all the forces in your diagram and only then you can talk about what a is. You just have to be careful with signs. In your example from page 2, for instance, the normal force is positive and g is negative which means that upwards is positive. Lift is accelerating downwards which means a is negative, which it is.
If you chosen g to be positive, than the normal force would be negative and a positive. Again everything is consistent.
FN = mg + ma
Actually, I did:Maxo said:Finally! This equation makes sense! Why didn't you just write this in the first place? ;)
(I used bold to represent vectors.)Doc Al said:If you insist, then apply Newton's 2nd law as a vector equation. It's the same derivation:
∑F = mg + Fn
mg + Fn = ma
I agree that would have been good if I had been told that. I wish I would have been able to formulate myself that was in fact was I was asking for already in the beginning but I guess I couldn't see it from such a "meta" perspective when I was struggling in the middle of the question so to speak.jostpuur said:When a discussion like this drifts to new confusing questions such as possible "signs of vectors", the side track should be discouraged. Maxo should have been told that vectors usually don't have signs, and if he insists on them having them, that would be a new concept which would require a new definition. Writing down a definition for this new concept would not help in the original problem though.
