Understanding the Train Experiment: Explaining Observers and Time Perception
  • Thread starter allebone
  • Tags
    Layman
In summary, the clocks on the train will not be synchronized at the end of the experiment, even though the observers on the train see them as being in sync.
  • #36
Joanna Dark said:
After consideration, in my first explanation of length contraction, I seem to have forgotten about time dilation. It's difficult to put them all together at the same time.
No it isn't. Look at the diagram I provided. Length contraction, time dilation, and relativity of simultaneity. And all together at the same time.
  • #37
Right.
So if that is true then the observed length contraction actually occurs. The train "actually" is shorter from the platform. The platform "actually" is shorter for the train observers.
Now we have a problem because you objected so often to me saying the the moving clocks "actually" ran slow and that this violates SR. Why can I say that length contraction actually occurs for the moving train, if I'm on the platform, but I can't say that about time dilation? In my understanding both should actually occur.
Hmm Doc. What's up here?
  • #38
Joanna Dark said:
Right.
Right.
We're getting tangled up in semantics a bit. What I object to is specifying a clock rate without specifying as measured by what frame. To say that a clock is slow (or fast) is meaningless without specifying who is doing the measuring. It would be just as meaningless to say that the train is a certain length without specifying according to who.
Does that help?
  • #39
Well I'm not so sure about the semantics but, as you can understand, this helps a lot.
So after our little word mix-up, and after analysing length contraction, I'm back to: A moving train is "actually" shorter and its clock "actually" runs slow for the platform observer. The platform is "actually" shorter and its clock "actually" runs slow for the moving train observer. Got it after a few days, and now you can't change my mind on this thankfully :approve:. Now I can run my experiments properly.
I have to figure out how this would be possible.
Let's head back to Sarah's example for a moment. Light travels at a constant speed for all observers. In this example the stationary observer sees a light beam travel 10ft at c and the moving observer sees the same light beam travel 20ft at c.
If the train observer measures the light beam speed by observing the platform clock what would the result be? Hmmm...?
The light beam travels 20ft at c on the passenger's and they now time the light beam on the station clock. The stationary observer times the light traveling 10ft at c. The distance is doubled for the passenger. So I would need to slow down the station clock by half, (for the perspective of the passenger in this example) to see the same time as the platform observer. Unless simultaneity affects my ability to do this. Yes? The stations's clock should be running fairly slow but could I say it's half the speed ? Let's correct for the movement of the train by using two passengers on the train to measure the speed of the stationary clock (just like the first experiment I set up). I'm not sure but am guessing I'm right.
  • #40
I'll reset the experiment. Two observers on the train with synchronized clocks 20ft apart. The train is traveling at a velocity where the Platform observer sees the light beam travel only 10ft.
At the exact time the front observer (Fr) passes the platform observer (P) he also shines a light beam towards the back observer (B). When the (B) sees the light hit his sensor would it be the exact same time he passes (P).
  • #41
OK. At some point TN sends a light beam towards TS. In the train frame, the distance between TN and TS is 20ft, so in the train frame the light travels 20ft. But the speed of the train is such that as seen by the platform observers the light only travels 10ft.
No. In the platform frame the light travels 10ft before hitting the back train observer (TS). So when TS "sees the light", he must be at a point that is 10ft south of P according to the platform observers. (TS will agree that he is south of P when he sees the light, but will disagree that he is 10 ft south of P.)
  • #42
That couldn't be. P is perpendicular to TN when the light flashes. P sees the light travel 10ft. Then by the time he sees the light hit the back of the train, TS is 10ft south. That means the train is ten feet short and stationary.
Doc this train is traveling at a tremendous speed.
Are you ok? Or just a little tired?
  • #43
Right. So where is the light when it reaches its target?
Exactly! (According to the platform observers, TS is 10ft south of P when the light hits him.)
:rolleyes: How do you figure that?
Indeed it is!
I'm fine. Thanks for asking. :smile:
Hey, you are the one who said the light travels 10ft according to the platform! Platform observers see the light begin at point P and travel south for 10 ft. That's what "travels 10ft" means.
  • #44
Oh no I had the train traveling 180000 times faster than the speed of light.
  • #45
Huh? :confused:
FYI: To meet the conditions you described, the train needs to travel at 3/5 the speed of light. (Assuming I did the calculation correctly.)
  • #46
The problem as I see it is I am trying to run an experiment I'm not sure is even possible. It's extremely complicated, however the result should explain roughly what is happening, so I'll go with it anyway. It is difficult to follow I know, but is based on the premise that if I could see a moving clock I could have a better understanding of what is happening in relativity. It includes time-dilation, length contraction and simultaneity in the one experiment. Read it through before commenting and ignore the errors please.
On the train there are two observers, train north (TN) and train south (TS), who are 20ft apart and traveling north.
The platform has two observers of it's own, platform north (PN) and platform south (PS), who are 10ft apart on the platform.
When TN passes PN he shines a light (L1) south towards TS, and the train is traveling at such a velocity where, TS's sensor sees the light as it is perpendicular to PS.
When PS passes TS he shines a light (L2) nouth towards PN.
I have two points on each side with which to time the speed of the train. PS and PN record the time it takes for TN to travel between them and TN does the same but records a lesser value (just like my first experiment). TN and TS record the time that it takes PS to travel between them and PS does the same but also shows a lesser result.
So that is the set up and now we will try to use it.
L1 travels 20ft at c for observers on the train and 10ft at c for observers on the platform, which is half the distance in half the time. L2 travels 10ft at c for platform observers and 5ft at c (I'm guessing here, but is not overly relevant) for train observers, which is half the distance at half the time.
They are timing the same light beam, so I'm thinking hypothetically that the platform observers should see the train observers clocks operating at the same speed as their own clocks, thus timing the light travel 10ft at c.
I'm not sure this part is even possible, but bear with me for a minute and let's pretend we could. In the end it seems to confirm what SR is saying.
The platform observers time L1 on the TN's clock traveling 10ft at C. This would mean that the train observers clocks are going half the speed of the platform clock in their own frame but don't recognise their clocks are running slow.
If I reversed the situation then the same thing should occur.
When PS, PN, and TN time the journey between PS and PN they all agree on the location of each observer but the distance between the two is shorter for TN. So in my hypothetical above I'd assume that PS_PN and TN would agree, but they don't. I'm guessing that TN's time should be closer to half of PS_PN but he also believes he traveled half the distance. TN thinks he only traveled 5 ft. So from the platform while they should see TN's clock timing L1 travel 10ft at c TN says his clock only elapsed about half that time.
So from this I could possibly make the assumption: It wouldn't matter whether the platform observers see the light travel 10ft at c (on the train's clock) and be correct or c/2 and be correct, because, for the train observers the light has only traveled 5ft. Thus making sense and alleviating the contradiction I saw previously.
But that is to say that the light traveling between the two points doesn't occur simultaneously. PN sees the light arrive early and PS calculates the light leave late. TS and PN agree with TN (when he shines the light) but TS doesn't agree with PN on the arrival time.
So when I put it altogether I can see how relativity works without necessarily contradicting itself. But, and this is a huge but, it does require accepting something that doesn't follow any logical sense. If my clocks are traveling slower than yours and yours are traveling slower than mine, then you could look at it as our clocks are simultaneously running normally and slowly at the same time. How do I deal with that?
If experiments into SR really work, and are empirical, then I would need to accept it without the necessity of logic. Extraordinary claims require extraordinary evidence, so I now need to study this evidence.
Thanks so much Doc for you patience.
  • #47
There is nothing at all illogical about this! Consider a spatial parallel.
Let's say two surveyors are marking out coordinates (meters North, meters East) of different landmarks from the same reference point. One is using magnetic north and the other is using celestial north which differ by e.g. 20º. Each will find that the other's "meters North" is short by a factor of cos(20º). They will each also find that the other's "meters East" is short by the same factor of cos(20º). Go ahead and work out the geometry for yourself to confirm that I am correct.
What is illogical about a rotation?
  • #48
Therefore relativity is logical. It follows from its postulates, and is self-consistent.
Relativity is counterintuitive for people who have not had practice in thinking in relativistic terms. This is not the same thing as being illogical.
Here is a large collection of references to experimental evidence:
Experimental Basis of Special Relativity
  • #49
Well my understanding is premature because I have disregarded 3 factors: aceleration, deceleration and total time dilation.
Someone on this thread stated that the train clocks needed to be sychronized and stopped before any change in velocity occurs. The train's clocks are out of sync for the platform observer. So a ref sync'ed the clocks when the train was stationary and rechecked at a constant speed they would have changed. I'm going to take a stab in the dark and suggest the south clock is traveling faster than the north clock.
I don't know whether decelleration should begin to bring the clocks closer to sync again, but that would be my best guess. The same should occur for the stationary clocks when viewed from the train frame.
Now for total time dilation. I am led to believe that if a plane flys around the equator for a long enough time it's clock won't match airport clocks. Same with satellites. A trip to Neptune and back would cause a great time difference suggesting that a person taking this trip would hypothetically actually be younger than a person on earth.
This could affect this new symmetry I've come to understand as one clock is actually going slower than a stationary clock. This I think is where my confusion arose in the first place.
Is this total time dilation caused by movement in general or only by aceleration and decelleration? My guess would be even a constant velocity would cause time dilation. Well I wonder if a plane traveling at a constant speed compared to a plane that acelerates and decellerates so both plane's average speed is the same, whether they will both experience the same total time dilation at the end of the journey.
I don't know how this effects my illogical/counter-intuitive understanding of special relativity.
  • #50
FYI: To fully understand just about any relativistic thought experiment requires all three: time dilation, length contraction, and simultaneity.
OK.
OK.
OK. This defines the relative speed of the train and platform to be 3/5 c.
OK.
They both measure each other's speed to be the same value: 3/5 c. And they both measure each other's clocks as running slow (compared to their own) by the same factor. (That factor = 1.25, by the way.)
OK.
Nope. Platform observers "see" (really, measure) the train clocks as running slow. And vice versa.
Sorry, not sure how platform observers would time something using train clocks. You'd have to define exactly what you mean by that. And the speed of light is measured to be c, but only if you use your own clocks and lengths in the usual manner to measure the speed of light with respect to you.
They agree on the definition of the two events: (1) TN passes PS, (2) TN passes PN. But they don't agree on the location, distance, or times. (On the train, TN doesn't even move--it's the platform that moves.)
The analysis of how the platform measures the light to travel 10 ft while the train measures it to travel 20 ft is more complicated than that. It involves length contraction as well as time dilation. (And to understand it from both points of view also requires simultaneity.)
You lost me a bit. Now you're talking about L2, not L1. Per your setup, L2 travels 10 ft on the platform, but only 5 ft according to the train.
Not sure what you're talking about here. But it's certainly true that each frame sees the other's clocks as being out of synch. (Which helps explain how they can both measure the speed of the same beam of light to be c.)
You still seem unable to shake the idea that clock rates depend on the frame in which they are observed.
It's not logic that needs to be abandoned, but certain of your premises about how the world works.
Always a good idea.
  • #51
I wanted to see what would happen if the platform observers recorded L1 on the train's clock and wondered if they would agree it is traveling at c. Someone in my class asked the question why the speed of light is constant but we use two clocks operating at different speeds to measure it? That made me curious.
In the end I worked out that the trains clock is running slower but for the train observers they had traveled an equally less distance. The platform observers agree on the time L1 left TN and when it hit TS's sensor. But the train observers disagree.
TN thinks that PS saw the light arrive in double the time he claims. TS saw TN flash his light earlier than PN claims he did. Or another way to look at it, TN and PN agree that they were perpendicular when TN flashed his light. TS doesn't agree they were perpendicular, he believes that PN is much closer and therefore PN's clock is slow. The same in reverse if I conducted the experiment regarding L2.
How could I observe the speed of L1 using the train's clock? In my first experiment I set up 3 observers to record the "time elapsed" between two points (F and S) from the trains perspective (T) and the tracks perspective (F,S). The string of sensors I set up parallel to the tracks between F and S, I didn't use, because in the process I realized it would achieve the same result as T on the train, but the only difference is that it records each second of the T's clock from multiple stationary positions. In theory, using a computer and a string of sensors, I could watch a moving clock next to a stationary clock and therefore time the speed of light on the moving clock.
What I expected would occur didn't (that for the platform observers both clocks would see light travel at c) but in SR that is to be expected.
So to answer the original question: If light is constant why do we use 2 clocks speeds to time it?
We don't. The light travels only one distance between two points and the clocks are operating at the same speed in their own frames. The only reason there is a difference of opinion is because from the platforms perspective, meters and seconds are smaller and out of sync. But otherwise both agree that L1 traveled between point A and Point B at v=c.
The way I have explained the situation sounds really simple though, when it's not. If a person snaps their fingers on both hands, did they do it simultaneously? For some, traveling at a certain velocity and direction, they did, for some the right one snapped first and others still saw the left one snap first. Those who saw the right hand snap first will not all agree on the delay before the left hand snaps. If you are to accept SR then you need to understand that all answers are simultaneously correct and there is no way to know when each hand snapped, unless you are basing this on a single set of frames.
I would still like to know how aceleration and deceleration and total time dilation affect my understanding as per my last post.
