Doc Al
Mentor
- 45,585
- 2,461
That's a good definition of illusion. Note that when talking about observations made by observers in different frames we are almost always talking about measurements, not just what they literally "see". Generally we view a frame as having as many clocks and observers as we need so that for any event we want to measure, we have an observer right there--so there's no optical illusions or light travel time to worry about.Joanna Dark said:You see Doc:
If I see your clocks going slow and I measured it as going the same speed as mine. Then it was an illusion.
If you measure my clock going slow compared to yours, and I measure my clock going slow compared to yours, then the relative clock rates would be a frame-independent fact. (But clocks don't work that way!) Note that there are frame-independent quantities.If I measured your clocks going slow and you agreed they were slow. Then it's a fact.
Yes. But when reporting observerations made within a frame we always assume that such corrections have already been made. (Except when literally talking about what people "see".) But you are correct. Example: If I see two explosions at the same time (meaning: the light from both explosions hits my eyes at the same time), it would be pretty foolish of me to claim that the explosions were simultaneous unless I know how far away they occurred.If I measure your clocks to be going slow and it's a fact but you don't agree it's a completely different ball game to comparing two perspectives at rest with one another. The third situation is obviously SR works. That is what I mean.
Now let me see if I have this right: in a vacuum if I saw two syncronized clocks at rest with respect to me, depending on my position and their distance apart, they might appear unsyncronized. I still see them operating at the same speed, so I could correct for this discrepancy if I know the co-ordinates of the clocks.
Careful here: Clocks that move with respect to you "really are" unsynchronized as far as you are concerned. It's not an optical illusion that goes away once you correct for distance and light speed. (We assume you've done all the corrections already before reporting your observations.)But if I am moving I also need to be aware of length contraction. The clocks are operating at the same speed, varying distance makes them appear out of sync and operating at a different speed, but because of length contraction I can't simply correct for varying distance between myself and the clocks. Distance is also out of whack.
I'm going to take a crack at rewording this setup so that it's clearer (at least to me). Let's assume that the train travels north. Let's arrange for two locations on the platform to be some distance (D) apart. Call them PN (platform north) and PS (platform south). Also define a location right in the middle: PM. Put clocks and observers at all three points. Also put some explosives at PN and PS.So let's revisit the first experiment in this thread. I'm going to set it up a little differently though so I know exactly what is going on with length contraction.
I'm going to set my contractors to work taking off the top of the train and the seats so all we see from the train station platform is a moving stage. They will also set up two triggers 20ft apart on the port side of the train. While I'm doing that we'll set up two piles of gun powder 20 ft apart on the edge of the platform. The first trigger needs to be set up so it doesn't set off the first pile of gunpowder it passes. Otherwise my experiment is stupid. I want them both to be extruding from the train so they merely touch the piles as they pass, so the first trigger will need to be extended as it passes the first pile. I could possibly be more technical than this but that will do for me.
If relativity wasn't a true phenomena then they should be set off at the exact same time according all observers. This experiment is perfectly symetrical so we should see something strange happening with the triggers. Will they be set off at the same time and observers will not see the events occurring as they are, or would the triggers actually be hit at different times? I have no idea.
So we will have an observer on the train (F1) and one on the platform (F2) recording the time the first trigger sets off the first pile and and the same for the second pile (S1 on the train S2 on the platform).
We will set up a ref in the middle of the train (R1) and in the middle of the two piles of gunpowder (R2) to see exactly when their respective two observers see the trigger hit.
According to special relativity the train is shorter for the platform observers and the platform is shorter for the train observers. In Einstein's experiment, for the platform observers it is the back of the train that is shorter, so the hind trigger should hit first. From the train observer's perspective it is the opposite so the front trigger should hit first.
From F1 and F2's perspectives the first trigger should hit at the same time. From S1 and S2's perspective the second trigger should hit at the same time. I seem to be having difficulty deciding what all the other perspectives in this situation would be. Could you help me out?
On the train, let's do something similar. Let's have locations TN and TS some distance D' apart. And a spot right in the middle: TM. Again, clocks and observers everywhere. TN and TS have special triggers that set off the explosives at PN and PS respectively, when they pass.
I think what you want is that when the train passes the platform, TN & PN, TM & PM, and TS & PS all pass each other at the same time according to the platform clocks. So the two explosions happen at the same time according to the platform clocks. Right?
(If relativity didn't apply, then all clocks will always be synchronized and read the same time. Also, D' and D would be equal. And everyone will observe--measure--the two explosions happening at the same time.)
Given this setup, we can talk about train observations versus platform observations.
. Now I can run my experiments properly.
