Unexpected Behavior of (1+x)^1/x Near Zero
  • Context: Graduate
  • Thread starter Thread starter trekie
    Zero
The discussion revolves around the unexpected behavior of the function f(x) = (1+x)^(1/x) as x approaches zero, particularly its apparent oscillation in values when plotted over a very small range around zero. Participants explore the implications of this behavior, its mathematical properties, and the reliability of computational tools like Wolfram Alpha in representing this function.
  • One participant notes that f(x) appears to oscillate near zero when plotted, despite earlier expectations of smoothness.
  • Another participant questions the meaning of "oscillate near zero," suggesting it may refer to infinitely many zero derivatives approaching zero.
  • Concerns are raised about the reliability of Wolfram Alpha's graphical representation of the function, with one participant suggesting that the oscillations may not be real but artifacts of the computational method used.
  • There is a discussion about the behavior of the derivatives of f(x), with one participant asserting that the discontinuities in the derivatives are not removable.
  • Another participant proposes that the oscillatory behavior could be a result of the Taylor series approximation used by computational tools.
  • Some participants express skepticism about the oscillation being a genuine feature of the function, attributing it instead to numerical noise in calculations.
Participants express differing views on whether the oscillation is a real phenomenon or an artifact of computational methods. There is no consensus on the nature of the behavior of f(x) near zero, and the discussion remains unresolved regarding the implications of the oscillation and the behavior of its derivatives.
Limitations in the discussion include assumptions about the behavior of f(x) near zero, the dependence on the accuracy of computational tools, and the unresolved nature of the mathematical properties of the function's derivatives.
trekie
I noticed some unexpected behavior in the real-valued f(x)=(1+x)^1/x, as a function of real numbers, when plotting it on wolfram alpha. I inputed:
plot (1+x)^1/x from x=-0.0000001 to x=0.0000001
and saw that it unexpectedly seemed to oscillate near zero. I took a closer look with:
plot (1+x)^1/x from x=-0.00000000001 to x=0.00000000001
and saw that it definitely seems to oscillate near zero. My original rough graph on paper using a hand calculator suggested the curve was smooth near zero, and even windows calculator's 32 decimal places were unable to reveal the oscillation when I manually calculated many different values near zero.
I don't think f(x) is smooth near zero, though, since
d/dx[f(x)]=f(x)d/dx[1/xln(1+x)]
so all of f(x)'s derivatives have a discontinuity at zero. Since Leonhard Euler showed limf(x)=e as x approaches zero, and this limit is the same as you approach zero from the left or from the right, then the discontinuity of f(x) at zero is removable and the function
f(x)=(1+x)^1/x, x not = 0
f(0)=0 x=0
is continous. But the discontinuities in the derivatives don't appear to be removable. Each derivative will have a term containing the factor 1/x (not the 1/x in the exponent of f(x)) which cannot be removed. E.g.
d/dx[f(x)]=f(x)[(1/x)(1/(1+x)+(-1/x^2)(ln(x+1))]
the 1/x in the 1st term is not removable.
I'm not saying it doesn't oscillate near zero, I'm just saying that this is unexpected. I need confirming opinions and confirming logic to explain it so I can believe it.
So the questions are:
1. Does f(x) oscillate near zero?
2. Why does f(x) oscillate near zero?
3. Why does this behavior not appear until |x|<~10^-7?
4. Is it a glitch in Mathimatica? [doubt it]
5. If it doesn't oscillate [which it probably does] then how is the behavior of the derivatives explained near zero?
6. If it oscillates, then why is it so hard to replicate this oscillation manually on a calculator?
Note#1: This behavior concerns the real-valued f(x). I don't think Re[f(z)] or Im[f(z)], z complex, are of interest here.
Note#2: This behavior concerns (1+x)^1/x. I don't think either (1+1/x)^x or lim(1+1/x)^x as x goes to infinty are of interest here.
Thx in advance and Kudos to the person with the explanation!
Hi trekkiee! :smile:
(try using the X2 tag just above the Reply box :wink:)
trekkiee said:
f(x)=(1+x)^1/x
When you say "oscillate near zero", you mean that it has infinitely many zero derivatives approaching zero?
But f'(x) = 0 if (1+x)ln(1+x) - x = 0,
and the derivative of that is ln(1+x), which always has the same sign as x.
Hm..just read it, don't really have time to work on it. Maybe try setting f(x) = 1 and seeing if it has multiple intersections on x:(0,1)?
But what about when you combine both terms together? For a rough approximation of how things might work out, recall that log(1+x) ~ x when x ~ 0.
The same original post was made here: http://www.scienceforums.net/forum/showthread.php?t=48648.
Synposis: Those oscillations aren't real. They are merely a result of how Wolfram alpha does real arithmetic. The singularity is removable. In the vicinity of x=0, the function f(x)=(1+x)^(1/x) is approximately a straight line with y intercept = e and slope = -e/2.
Bohrok said:
However, when I graph their difference, wolfram gives a graph with a lot of oscillations that shouldn't exist, yet says the result is 0 as it should be.
Well, you should be clued in by the extremely small amplitude of the oscillations that you're simply looking at noise.
i left a reply for this at www.advancedphysics.org[/URL], that should give you the right answer :)
its too long to rewrite
Thx all for the replies. I should have known the problem was mathematica's [wolfram alpha] behavior when doing certain calculations.
Wolfram is probably using a Taylor series with many terms to do the ln (1+x) calculation, which would produce the oscillatory behavior.
  • · Replies 24 ·
