Unexpected Result on TI-89 Titanium for Equation with Negative Exponents
  • Context: Calculators
  • Thread starter Thread starter kald13
    Error Ti-89 Titanium
The discussion revolves around unexpected results obtained from calculations involving negative exponents on the TI-89 Titanium calculator. Participants explore the implications of operator precedence and the use of different notations for negative numbers in mathematical expressions.
  • One participant reports an unexpected result of -4 when calculating the expression 2(-2^3)-3(-2^2), while independently calculating the components yields -16 and 12, respectively.
  • Another participant questions the interpretation of -22, suggesting it could mean either -(22) or (-2)2.
  • Some participants clarify that the expression 3((-)2^2) should evaluate to -12 due to operator precedence, while others suggest that the original expression may have been misinterpreted.
  • There is a discussion about the correct use of parentheses to clarify the intended operations, with one participant suggesting that the notation used is to distinguish between unary and binary operators.
  • Several participants mention that the TI-89 has two different minus keys, one for unary negation and one for binary subtraction, which may contribute to the confusion in calculations.
  • One participant expresses confusion about the notation and its implications, indicating a lack of familiarity with the specific notation used on the TI-89.
Participants express differing views on the interpretation of negative numbers and operator precedence, with no consensus reached on the correct approach to the calculations or the notation used.
Participants note that the results may depend on how the expressions are entered into the calculator, highlighting the importance of understanding operator precedence and the distinction between unary and binary operations.
kald13
I was working with a much longer equation and receiving a result I didn't expect, and finally narrowed it down to the following section:
[itex]2(-2^3)-3(-2^2)[/itex]
2(-2^3) is correctly calculated as -16 independently, and 3(-2^2) is correctly calculated as 12 (again, independently) for a difference of -28, but my calculator is returning -4.
No matter how I enter the equation, the only way I obtain a correct result is by first defining a variable as -2 and then substituting that variable in for -2 in the equation.
Is this problem repeated on anyone else's unit? And if you've encountered this sort of problem before, is there a way to correct it?
Computer science news on Phys.org
Is -22 intended to mean -(22) or (-2)2?
I will use (-) for the negative operator
I hope 3((-)2^2) is not calculated as 12 that would be very wrong
3((-)2^2)=-12 due to operator precedence
2((-)2^3)-3((-)2^2)=2((-)(2^3))-3((-)(2^2))=-4
perhaps you had intended to write
2(((-)2)^3)-3(((-)2)^2)=-28
There are a number of different ways to enter the problem to achieve the intended result. I have tried a few variations, all with the same results.
[itex](2*((-2)^3))-(3*((-2)^2))=-4[/itex]
[itex](2*((z)^3))-(3*((z)^2))=-28[/itex]
This is a piece of the derivative of a function, and -2 is one of the zeros of the derivative signifying a local maximum in the function. The intent is to solve the equation when z=-2 (among other values)
Incidentally, entering the equation in the calculator as I originally did produces the same results; the intent is not to find -(2^3) (which is -8) but (-2^3) (which is also -8, but for a different reason).
[itex](2*-2^3)-(3*-2^2)=-4[/itex]
[itex](2*z^3)-(3*z^2)=-28[/itex]
^Of those four only the first one is surprising. If that input gives that output I am quite confused.
What happens if you enter
2((0-2)^3)-3((0-2)^2)
I do not have a ti89 handy
I do know that the manual gives the example
((-1)2)^2=4
(-)2^2=-4
The above is a very silly use of parentheses.
(-2)2 should evaluate to +4.
-22 should evaluate to -4.
The trouble with this notation, above, is that the - sign is not binding to anything.
^It is not silly, it is to distinguish between the unary and binary operators. It is the same notation used on the calculator keypad. For you special
3(-<<<the unary one>>>2^2)
to quote the manual
$$\text{Important: Use }\bbox[3px,border:2px solid black]{\phantom( - \phantom)}\text{ for subtraction and use }\bbox[3px,border:2px solid black]{(-)}\text{ for negation.}$$
Mark, not sure if you know it, but TI-89 has two different minus keys.
The one with "(-)" is an unary "change sign" operator, the other is a binary "minus". Hence the "(-)" and "-" notation is just reflecting the reality.
No, I didn't know that. That notation seems to be fairly new in calculators. Calculators have been distinguishing between the unary minus and binary subtraction operator for a long time, but using +- for the unary operation and - for subtraction.
I didn't realize that lurflurf was using (-) to mimic that key on the TI-89.
The [(-)] key doesn't mimic a [+/-] key, it correctly implements the operation of negation in normal mathementical notation which is to negate the following argument, whereas the normal implementation of a [+/-] key is to negate the argument currently displayed.
Note that page 943(!) of the manual states:
To enter a negative number, press [(-)] followed by the number. Post operations and exponentiation are performed before negation. For example, the result of -x2 is a negative number, and -92 = -81.
Now that I look at the picture of my TI, I think it is time to clean it :blushing:
17K
