Understanding Uniform Continuity to Formalizing Proofs
The discussion focuses on the formal proof of uniform continuity in real analysis, specifically proving that if a function f is uniformly continuous on R, then for any two sequences xn and yn where lim(yn - xn) = 0, it follows that lim(f(xn) - f(yn) = 0. Participants emphasize the importance of correctly using the terms "sequences" instead of "series" and provide a structured approach to formalizing the proof by defining ε, δ, and N clearly. The final formulation demonstrates how to derive the conclusion from the definitions of uniform continuity.
  • Understanding of uniform continuity in real analysis
  • Familiarity with limits and sequences
  • Knowledge of ε-δ definitions in calculus
  • Ability to construct formal mathematical proofs
  • Study the ε-δ definition of uniform continuity in detail
  • Practice formalizing proofs involving limits and sequences
  • Explore examples of uniformly continuous functions
  • Learn about the implications of uniform continuity in functional analysis
Students of mathematics, particularly those studying real analysis, educators teaching calculus concepts, and anyone interested in formal proof writing in mathematical contexts.
sergey_le
Prove that if f Uniform continuity in R, then for any two series xn and yn limyn-xn=0 so limf(xn)-f(yn)=0
Uniform continuity
There are two parts to the question Let's start with part :)
I understand the definition of Uniform continuity And I think I'm in the right direction for the solution but I'm not sure of the formal wording.
So be it ε>0
Given that yn limyn-xn=0 so For all ε>0 , ∃N∈ℕ so that For all N<n , |yn-xn|<ε so ∃δ>0 so that |yn-xn|<δ And because f is Uniform continuity
|f(yn)-f(xn)|<ε.
I know my formulation is not good but I can't formalize it nicely
sergey_le said:
Homework Statement:: Prove that if f Uniform continuity in R, then for any two series xn and yn limyn-xn=0 so limf(xn)-f(yn)=0
Homework Equations:: Uniform continuity
So be it ε>0
|f(yn)-f(xn)|<ε.
The correct term is sequences. Not series.
I think you got the right idea but it contains some mistakes.
Let ##\epsilon>0##. Choose ##\delta>0## as in the definition of uniform continuity.
Choose ##N## such that ##|x_n−y_n|<\delta ## if ##n\geq N##.
Can you conclude?
Likes sergey_le and PeroK
So be it ε>0
|f(yn)-f(xn)|<ε.
You must be much clearer about how you get ##N, \delta, \epsilon##.
Hint: try working backwards from the way you did it:
Let ##\epsilon > 0##
How do you get ##|f(y_n) - f(x_n)| < \epsilon##?
Answer: if ##x_n, y_n## are close enough together. This gives you ##\delta## (depends on ##\epsilon##).
How do you get ##x_n, y_n## close enough together?
Answer: by taking ##n## large enough. This gives you ##N##, which depends on ##\delta##.
Can you formalise that strategy?
Likes member 587159
I understand what you mean I tried for an hour now to translate my formulation into English.
But my English is not good and it turns out really not good.
I'm not sure how I write the passage from that if |xn−yn|<δ so |f(yn)−f(xn)|<ϵ
I'd love if you could help me with that.
Can you conclude?
The correct term is sequences. Not series . Thanks I will use it
Can you please help me with a formal wording: /
Let ##\epsilon > 0##. Because ##f## is uniformly continuous, we may choose ##\delta > 0## such that for all ##x## with ##|x-y|< \delta## we have ##|f(x)-f(y)|< \epsilon##. Because ##\lim_n (x_n-y_n)= 0##, there is ##N## such that ##|x_n-y_n|< \delta## whenever ##n \geq N##. Thus, combining the two previous statements, we get ##|f(x_n)-f(y_n)|< \epsilon## whenever ##n \geq N##. Thus we have proven that for any ##\epsilon>0##, there is ##N## such that ##|f(x_n)-f(y_n)|< \epsilon## whenever ##n \geq N##. This is exactly the definition of ##\lim_n (f(x_n)-f(y_n)) = 0## and we are done. ##\quad \square##
Likes sergey_le
Thanks so much for your understanding.
This stuff is new to me and I need to get used to a good formulation
  • · Replies 37 ·
