Uniform Distributed Electric Charge
11 replies · 10K views
stylez03
A ring-shaped conductor with radius a = 2.20 cm has a total positive charge Q = 0.123 nC uniformly distributed around it.
(Question relevant to main problem)
(a)What is the magnitude of the electric field at point P, which is on the positive x-axis at x = 35.0 cm?
[**Actual Question**]
A particle with a charge of - 2.70 mC is placed at the point P described in part (a). What is the magnitude of the force exerted by the particle on the ring?
F = 1/4*pi*e_o * |q| / r^2 for single point charge
e_o = 8.85 * 10^-12
1/(4*pi*8.85 * 10^-12) * ( 0.123*10^-9 * 2.70*10^-9 / .35^2 )
The online system says I'm off by an additive constant,
I also tried
1/(4*pi*8.85 * 10^-12) * ( 0.123*10^-9 * 2.70*10^-9 / .35^2 + 0.0220^2)
Since that equation was also in the book, but still no luck.
The electric fields at a point due a to a charge distribution is given by:
[tex]\mathbf{E} = \frac{1}{4\pi \epsilon_0} \int \frac{\sigma}{r^2} \mathbf{\hat{r}} dl[/tex]
[itex]\sigma[/itex] is the charge density of the ring of charge.
Given your equation:
e_o = 8.85 * 10^-12
rho = 0.0220m
r = .35m
I'm not sure what r_hat is in this situation?
The r-hat is the unit vector pointing in the direction of the field. You will have to perform the integral which will be different depending on what coordinate system you use.
Do you have a diagram? The geometry is important aswell. I assume the axis of rotation of the circle is the x-axis.
Here is the diagram:
http://www.uploadyourimages.com/view/505148yf.figure.21.21.jpg
Oh hang on problem diagnosed. You've put 2.7 nC in the equation instead of 2.7mC (2.7x10-3). I jumped the gun and started answering the first part.
Your original method should work you just mistook the units of one of the charges. When I said I jumped the gun I wasn't kidding I had you on the path of deriving the equation you already had. I just didn't recognise it at first because you'd put all the numbers in instead of symbols.
I must be cursed with you. I keep sending you down the wrong path :eek: many apologies.
it's okay. Thankfully homework isn't worth much in my overall grade, least this will help me prepare for the exam which is worth a lot more.
