Uniform electric field and a proton
6 replies · 7K views
tag16
A proton moves at 4.50x10^5 m/s in the horizontal direction. It enters a uniform vertical electric field with a magnitude of 9.60x10^3 N/C. Ignoring any gravitational effects, find a) the time interval required for the proton to travel 5.00 cm horizontally b) its vertical displacement during the time interval in which it travels 5.00 cm horizontally c) the horizontal and vertical components of its velocity after it has traveled 5.00 cm horizontally.
a= qE/m
I know I need to use the above equation at some point in this problem but I have no idea how to go about finding the time interval.
Hi tag16! :smile:
Treat this exactly as you would a projectile under gravity …
calculate the acceleration, and do the x and y components separately. :wink:
ok for the formula for acceleration a=qE/m how do you find E? q= 9.60x10^3 right? thanks
(try using the X2 tag just above the Reply box :wink:)
No, q is charge, and is in coulombs (C)
E is the field, in Newtons per coulomb (N/C) … E = 9.60x103 :smile:
ok...not sure how to figure out q then since it's not given in the problem.
It's the same as the charge on an electron (times minus-one, of course) … does that help? :smile:
