Uniformly accelerating frame of reference
42 replies · 5K views
sweet springs
In an inertial frame of reference let numerous standard rockets that load synchronized standard clocks place on all the space lattice. Simultaneously the rockets start to move with same intrinsic acceleration to the same direction. In other words there exists a common instantaneous inertial frame of reference to all the rockets.
May I understand it as a description of uniformly accelerating frame of reference ?  If so I worry Rindler coordinates cover only part of the frame of reference. Is it OK?
No, there does not. The clocks will not generally keep being synchronised and the space ships will have different velocities in the instantaneous rest frame of any of them. I suggest looking up and trying to understand Bell's spaceship paradox.
At any time point of the acceleration, you can construct an inertial frame, where all the ships are instantaneously at rest. But the clocks of the ships have offsets in such a frame.
Thanks.
Very interesting. Do the corresponding clocks in an inertial frame and the ships differ with same amount or various values according to where they are ?
I don't think that this is correct. Given the problem description it seems that the rockets all have the same velocity in the original frame. So if you transform to any other frame the rockets will have different velocities. So they would not all be at rest wrt each other.
When are you doing the comparison? Note that there is a can of worms in the word "when".
As you have described the setup this is not true.
You should go through the math on this one and learn how to calculate this kind of thing.
Indeed, Dale is right here.
Assuming that when you say " Simultaneously the rockets start to move with same intrinsic acceleration", you mean what I think you mean that the simultaneity is defined by the initial inertial frame that the rockets are initially in, and that "intrinsic acceleration" means "proper acceleration", then you have Bell's spaceship paradox. The rockets will NOTkeep a constant distance apart, the distance between any pair of rockets will decrease with time. If you assign labels to the rockets based on their initial position coordinates in their initial inertial frame and use those labels as spatial coordinates, you'll have a perfectly valid coordinate system, but it won't be the Rindler coordinate system. Because the distance between any pair of rockets changes with time, the value of ##g_{00}## in this coordinate system will be a function of time. If this coordinate system has a name of its own, I haven't seen it. It's definitely not what's usually meant by a "uniformly accelerating frame". What's usually meant by a "uniformly accelerating frame" in the literature is an arrangement of rockets that keep a constant distance from each other, adjusting their acceleration profile as needed. This ensemble of rockets keeping a constant distance from each other defines the Rindler frame.
This depends on the frame you consider things in. In the instantaneous rest frame of one of the rockets, the distance between rockets will increase. In the original rest frame it will stay the same.
Thanks all for advice. Let me summarize my understanding here.
In an inertial frame of reference(IFR) let numerous standard space ships that load synchronized standard clocks place on all the space lattice, labelled with the coordinates. Simultaneously the ships start to move with same proper acceleration to the same direction.
a. There always is an instataneous IFR where all the ships are at rest.
b. In the instataneous IFR the distances between the ships in that direscion increase.
c. In the instataneous IFR the clocks are not syncronized in that direction. Faster forward, delayed backward in proportion to distance.
No. This is not correct. See posts 5, 7, and 8.
No, this is wrong.
And 2 ...
Thanks. I try correction.
a(revised). There always is an instataneous IFR where ships on a traverse line are at rest and others have different speeds in that direction. Faster forward, backward faster backward in proportion to distance.
Give me one more clarification please.
d. Let the ships have come to the initial fire state by having kept accerelation of the same manner at past. In an instantaneous IFR, distance of the ships in that direction were longer. The ships were coming closer.
It seems that a kind of bounce out from contraction to inflation takes place at the initial time.
Let me clarify the situation (hopefullly) by pointing out that there are two different notions of a line of rockets accelerating together, and they're not the same in Special Relativity (although they are the same in Newtonian physics):
  1. The line of rockets start off at rest in some rest frame, and then they all accelerate with the same acceleration profile (that is, they all accelerate such that they all "feel" the same g-forces).
  2. The line of rockets start off at rest in some frame, and then they all accelerate in such a way that the distance between the rockets remain constant--as viewed by the travelers on board the rockets.
These aren't the same thing. If the rockets all have the same acceleration profile, then
  • According to observers in the original rest frame, the distance between the rockets remains constant.
  • According to observers on board the rockets, the distance between the rockets steadily increases.
If the rockets keep the same distance apart (which is called "Born-rigid acceleration"), then
  • According to observers in the original rest frame, the distance between the rockets shrinks with time.
  • According to observers on board the rockets, the distance between rockets remains constant.
In the case of Born-rigid acceleration, the rockets do NOT have the same acceleration profile: the rockets in the rear have a larger acceleration (and feel greater g-forces) than the rockets in the front.
"Born-rigid acceleration" was new to me. Thanks.
"Uniformly accerelerating frame of reference" has uniformity of proper acceleration in time. I have misunderstood that Uniformity also means that all the ships share common proper acceleration.
In this context, proper accerelation values of not only one ship but also of another one (a higher or lower ship) toghether with the distance between are necesary to identify the "uniformly accerelerating frame of reference". Am I right?
The intuitive meaning is that an object undergoing Born-rigid (named after the physicist Born, not like "Born to run" or "Born to be wild") acceleration will feel no stretching or compression forces. In contrast, if you have a line of rockets accelerating with the same profile, then a string connecting the rockets will be stretched and will eventually break (that's Bell's spaceship paradox).
Let I be in a Rindler space. I do not where I am or my coordinate z and acceleration parameter of a of the system.
I obeserve metric here and get ##\sqrt{g_{00}(z)}=\alpha##.
I climb up h and observe metric and get ##\sqrt{g_{00}(z+h)}=\beta##
Applying them to the formula of metric,
##1+\frac{az}{c^2}=\alpha##
##1+\frac{a(z+h)}{c^2}=\beta##
Thus I get
##\frac{a}{c^2}=\frac{\beta-\alpha}{h}##, ##z=\frac{(\alpha-1)(\beta-\alpha)}{h}##
I have never seen such a way in textbooks. Do not we need such two point observation to identify Rindler space?
Or let us define time of the Rindler space be proper time where I am so that ##\alpha=1## thus z=0 here, a is acceleratin I am feeling. Does it work?
Yes, although I don't know if it is in proportion to the distance or the square of the distance or something. I would have to work out the math.
Yes, that sounds right.
It is relatively easy to work out, but you need to decide which distance you are talking about. As a matter of fact, I just gave essentially this problem to my students for their homework problems.
I was regarding the "frame of reference" as being defined by the congruence of worldlines of the rockets, as described in the original post:
Manoff [PLAIN said:
http://arxiv.org/abs/gr-qc/9908061][/PLAIN]
(c) Monad’s methods
. A frame of reference is identified with a non-null (non-isotropic) (time-like) contravariant vector field interpreted as the velocity of an observer (material point).
The point is that if the "material observers", i.e. the rockets all of whom share a constant proper acceleration, measure their distance to their nearest neighbors as changing with time. I.e. we consider some rocket A that's part of the congruence of worldlines, and some nearby rocket B. The rockets measure their distance to each other by exchanging radar signals - or, in Bell's spaceship paradox, by means of a string. In either case, the distance changes with time - in the Bell spaceship paradox, the string breaks.
The other point is that in the Rindler congruence, "the strings don't break", but the proper acceleration of the rockets varies with position. At the Rindler horizon, the required proper acceleration to maintain a constant distance to the other nearby members of the congruence becomes infinite.
Thanks for good discussions. Let me deepen my understanding.
The wrong answer a. seems to turn out to be right in another case that the ships are arranged to represent lattices of uniformly accelerating frame of reference. i.e.,
Simultaneously the ships start to move to the same direction with constant proper acceleration. Proper accerelation of ships are arranged so that ships on a traverse line have same proper acceleration and nearby traverse lines keep constant distance.
b. In the instataneous IFR the distances between the ships in that direcion are constant.
c. In the instataneous IFR the clocks are not syncronized in that direction. Faster forward, delayed backward.
d. Let the ships have come to the initial fire state by having kept accerelation of the same manner at past. In the instantaneous IFR, distance of the ships in that direction were constant.
Rindler coordinate is interpreted as continuous get off and on the instantaneous IFRs.
Let any place be z=0 where z-axis is the direction of acceleration, proper time there be time of the system and proper acceleration there be parameter of the system. Now I know that it describes Rindler space.
Thanks. .
sweet springs said:
Thanks for good discussions. Let me deepen my understanding.The wrong answer a. seems to turn out to be right in another case that the ships are arranged to represent lattices of uniformly accelerating frame of reference. i.e.,
The "frame of reference" in which all the ships are "at rest" isn't an inertial frame, because it has pseudo-gravitational forces due to the ships acceleration. Inertial frames of reference, by definition, don't have pseudo-gravitational forces, objects in them obey Newton's laws. Because "frames of reference" is rather ambiguous, I prefer to say there is a coordinate system (rather than a frame of reference) and that in this coordinate system all of the above ships have constant coordinates (rather than saying they are at rest).
This coordinate system has a space-time metric, the Rindler metric.
This coordinate system doesn't cover all of space-time. There are various ways of "explaining"
this, one of them is to point out that space-ships must have a finite proper acceleration, and that the required proper acceleration to hold station becomes infinite at what is known as the "Rindler horizon". Another way of looking at it is to look at the metric coefficients, and note that ##g_{00}## becomes equal to zero.
Thanks. The "frame of reference" in which all the ships are "at rest" INSTANTANEOUSLY is an inertial frame. The ships with their proper accelerations do not stay at rest in this IFR. Continuous transfer to such instantaneous IFRs make Rindler coordinate with gravitation.
Second try:
If you pick one specific observer from the congruence of observers, at any instant of time that observer has an instantaneously co-moving inertial reference frame, henceforth abbreviated as ICMIRF specific to that observer at that instant of time. Establishing that all the other observers in the congruence share the same instantaneously co-moving frame is something that needs to be determined. In general it's not true. The only way I know of checking this involves a fair amount of fairly advanced math. You represent an inertial reference frame by its basis vectors, ##\hat{e_x}, \hat{e_y}, \hat{e_z}##. To compare inertial reference frames, you need the concept of the connection coefficients and parallel transport. Given a metric, you can compute the connection coefficients and determine if it's true that the basis vectors in the second frame (which we will indicate by a prime symbol) are the same as the basis vectors in the original frame - i.e. that ##\hat{e'_x}=\hat{e_x}, \hat{e'_y}=\hat{e_y}, \hat{e'_z}=\hat{e_z}##. Fortunately, in the context of special relativity, parallel transport is path independent, so the notion of comparison of the basis vectors is well defined and path independent.
Some counterexamples of frames where the ICMIRF's are not shared are rigid rotating frames, where every point in the rigid rotating frame has a different ICMIRF, and expanding frames, such as the "Bell Spaceship" frame .
Thanks perverct. So I try to correct. In uniformly accelerating system the following applies again,
sweet springs said:
a(revised). There always is an instantaneous IFR where ships on a traverse line are at rest and others have different speeds in that direction. Faster forward, backward faster backward in proportion to distance.
where not "in proportion to distance" but in a subtle way so that the Bell's threads are not broken.
It is interesting that the speed of the both ends of thread are different in the ICMIFRs but the threads are not torn apart. The speed of the bottom line of the ships reach light speed.
