Finding the Inverse of a Number in a Finite Field
The discussion revolves around finding the inverse of b modulo m, given that m = 1 mod b. It is established that m can be expressed as m = kb + 1 for some integer k, indicating that b and m are coprime, which allows for the existence of an inverse. The equation xb = 1 mod m is derived, leading to the conclusion that x can be expressed as (m + 1)/b, although this does not always yield an integer. Participants express difficulty in manipulating the equations to find a satisfactory solution. The conversation highlights the importance of correctly applying the modular relationship to solve the problem effectively.
moo5003
Suppose that m = 1 mod b. What integer between 1 and m-1 is equal to b^(-1) mod m?
m = 1 mod b means that:
Let x be the inverse of b mod m, note: x exists since b and m must be coprime due to the previous statement.
xb = 1 mod m
thus: xb = gm + 1 for some integer g.
Now this is were I have little success. I can't seem to manipulate anything to my advantage and I'm unsure how to proceed.
I did find x = (m+1)/b but that is not always an integer. Thanks for any help you can provide.
Well, you don't seem to have made use of the fact that m = 1 mod b...
I thought I used that fact when using the statement
m = kb + 1 for some integer k, unless I'm missing something else. Little tired, but I will come back to it tomorrow.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
