Unstable or stable electrostatic equilibrium?
69 replies · 9K views
Angela G said:
ok, so If the charges has oposite sign, the there will be an attractive force when the point charge is displaced a dz from the ring, and know we have to determine the stability on the plane of the ring.
Also, I wonder if you could take a look at post #50, and tell me if my reasoning is right or not, pls
I don't think you were supposed to get into detailed calculations. That's why the question said simply "motivate your answer". You're looking for a good approximation for the force on a particle that is perturbed off centre.
You have examined $$- \frac{\partial^2 V}{\partial z^2} = \frac{1}{\rho} \frac{\partial}{\partial \rho} \left( \rho \frac{\partial V}{\partial \rho} \right )$$ This says that:
1. If one side of the equation is positive (it doesn't matter which) the other is negative.
2. The positive side means stable equilibrium in that direction and the negative side means unstable equilibrium in that direction.
Is that observation going to change if the signs of the charged ring and the test particle are the same as opposed to different?
This thread has gone on for too long in my opinion. One can find more details about the potential and electric fields near the origin (for like charges) in post #2 here.
I think you already have said the way the ring field acts and you know which way it makes a charge with a small displacement go for each sign of ##q##.
Just spell it out.
It is interesting to compare the stability in the plane vs. out of the plane along the ##z## axis in both cases (of like or opposite charges).
PeroK said:
Which is an unjustified assumption. ##\lambda## and ##q## could have opposite signs.
It was used as a starting case, that's all. The possibility of different signs were discussed earlier.
I think part ##a## is basically solved or at least enough was discussed to complete it, so what about part ##b##?
could you please summarize a) because I'm little confused
You solved the stability for the ##z## axis above and you know the direction and therefore force in the plane (toward the center for positive ring) and so you know whether it is stable in the plane of the ring given the sign of the charges. If you want to be more detailed for example on the ##z## axis just compute the potential along the ##z## axis which is easy because of symmetry and take the second derivative of it.
regarding to b) I think I already solved it could you please take a look of it
Edit: I missed a "q" in the third expression
Looks correct.
Thank you everyone that helped me in this problem I finally understood ☺️☺️☺️☺️
  • Love
