Understanding Friction: Forces and Coefficients Explained
  • Context: High School
  • Thread starter Thread starter kangta
    Friction Urgent
This discussion clarifies the relationship between friction, normal force, and the coefficient of friction. The equation F = μR establishes that the force of friction (F) is directly proportional to the normal reaction force (R), where μ represents the coefficient of friction. It is confirmed that a graph of force of friction versus normal force passes through the origin, indicating that if there is no normal force, there is no friction. Additionally, while the force of kinetic friction depends on the weight of the object, the coefficient of kinetic friction does not, as it is a property of the surfaces in contact.
  • Understanding of basic physics concepts such as force, weight, and friction.
  • Familiarity with the equation F = μR and its components.
  • Knowledge of the relationship between normal force and weight (R = mg).
  • Basic understanding of how surface area affects frictional forces.
  • Research the impact of surface materials on the coefficient of friction.
  • Explore experimental methods to measure frictional forces under varying conditions.
  • Learn about the role of surface area in friction and its implications in real-world applications.
  • Investigate the differences between static and kinetic friction coefficients.
Students studying physics, engineers working on material design, and anyone interested in understanding the principles of friction and its applications in mechanics.
kangta
1. Does a graph of force of friction vs force normal pass through the origin? Explain.
2. Does the force of kinetic friction depend on the weight of the object? Explain.
3. Does the coefficient of kinetic friction depend on the weight of the object? explain
This is not on an icline plane.
1. yes.
F = μR
μ does not = 0
where F = friction, R = normal reaction force and μ = coefficient of friction.
if F = 0, then R must also equal 0 to satisfy the above equation. therefore a graph of F against R would pass through the origin.
2. yes.
for an object moving on a horizontal plane, R = mg (where mg = weight). therefore, for an object moving on a horizontal plane:
F = μmg
3. no.
F is proportional to R and hence F is proportional to mg. μ is just the constant of proportionality. it is a property of the surface(s) experiencing friction. it is dependent upon the shape and material of the surfaces.
ummm i don;t get what those things mean...
what is R?
Can you explain it in a simpler way?
The equations given to me are
ì = Ff/Fn
Fnet = mg
in the equations given to you, what are i, Ff and Fn? you need to state what the symbols are representing.
in the equation i used, F is the frictional force acting on an object moving on a surface, R is the normal reaction force on the object and μ is the coefficient of friction between the object and the surface.
the frictional force F on the object is proportional to the normal reaction force R acting on the object:
F is proportional to R.
to turn this into an equation, a constant of proportionality is required. this is μ, the coefficient of friction:
F = μR
μ cannot = 0. if μ = 0 there would be no friction.
in a graph of F = μR, F would be the vertical axis and R would be the horizontal axis. μ would be the gradient of the graph. if the graph passes through the origin, then F must = 0 when R = 0. put R = 0 into the equation:
F = μ0
F = 0
so F does = 0 when R = 0 therefore the graph passes through the origin.
oop i meant u = Ff/Fn u = coefficent of friction, Fn = Force Normal, Ff = Force of friction.
Ok how about this question?
How does the surface area of the block affect the force of friction or the coefficient of friction?
Well the surface area will affect the force of friction because quite obviously, the more there is, the more it has to fight to get from A to B
kangta, the equation you are using is exactly the same as mine only the symbols are different.
you have used Ff for frictional force, and i have used F. you used Fn for normal reaction force, i used R. you used u for coefficient of friction, i used μ.
u = Ff/Fn can be rearanged to Ff = uFn, which is in the same form as i used.
the area in of the block in contact with the surface it is moving on affects the coefficient of friction u. u is a function of the area of the block in contact with the surface, and the material of the block.
Coeficient of friction includes surface area and surface area relates pressure and force. So if you increase surface area, the pressure decreases (for a given force) and the 'amount of surface to grab' increases by the same amount. So the friction force stays the same.
I'm not sure if that made sense, so let me try a mathematical explanation: if you break out a surface area term from the coefficient of friction, you also have to divide force by surface area (getting pressure). The two surface area terms cancel out.
this has nothing to do with pressure.
the coefficient of friction μ is a function of the contact area between the two surfaces amongst other things.
F = μR
μ = f(A) where f(A) is a function of the contact area. thus by changing A you change μ. by changing μ you change the frictional force for a given normal reaction force.
you can test this by experiment. two objects of identical mass but with different contact areas moving on a horizontal plane will experience different frictional forces.
this is why, for example, wide tyres give more grip than narrow tyres.
  • · Replies 26 ·
  • · Replies 35 ·
  • · Replies 17 ·
  • · Replies 17 ·
