Use Laplace to solve this differential equation
17 replies · 3K views · last reply
Northbysouth
Obtain the solution of the differential equation
x'' + w2nx = t
My use of L refers to the Laplace
L{x'' + w2nx = t}
I decided to do the Laplace of each part individually starting with x''
L{x''} = sL{x'} - x'(0)
then
L{x'} = sL{x} - x(0)
Putting this together gives
L{x''} = s[sL{x} - x(0)] - x'(0)
Also, the L{x} = x/s
L{x''} = sx - sx(0) - x'(0)
Then the Laplace of w2nx is:
L{w2nx} = w2nx∫inf0e-st dt
because I believe that w2nx is a constant, hence I can move it out of the integral
evaluating the integral then gives me
L{w2nx} = w2nx/s
Then for L{t} I can see from the Laplce tables that this is just 1/s2
Consequently, my Laplace transformation is
L{x'' + w2nx = t} = sx - sx(0) - x'(0) + wn2x/s + 1/s2
After this step I'm pretty sure I need to do the inverse Laplace transform. But I wanted to check if what I had at the moment looked right, and if so, what is the best way to do the inverse of this laplace transformation?
x'' + w2nx = t
L{x'' + w2nx = t}
then
L{w2nx} = w2nx/s
You're confusing the function x with the variable t. L[x] = L[x(t)] = X(s) while L[t] = 1/s. X(s), the Laplace transform of x(t), is what you're solving for.
I was thinking it looked a bit odd.
So Should it instead be:
[sL{x''} - x'(0)] + wn2[X(s) - x(0)] = 1/s2
This simplifies to:
s2X(s) - sx(0) - x'(0) + wn2X(s) - wn2x(0) = 1/s2
So, now I would solve for X(s), but what would I do after this point? Would I need partial fractions?
After you solve for X(s), you want to invert it to find x(t). Partial fractions will probably be useful to get X(s) into a form where you can invert it using a table.
Okay, I've solved it for X(s) and used the initial conditions x(0)=0 and x'(0)=0
This gives me:
x(s) = 1/(s2(s2+wn2))
Which I can break down into:
s/(s2+ wn2) * 1/s3
From the tables this, I think, gives me:
cos(wnt) * t2/2
How does this look?
The Laplace transform is a linear operator. That means if you have two transform pairs x(t), X(s) and y(t), Y(s), then L[ax(t)+by(t)] = aL[x(t)]+bL[y(t)] = aX(s) + bY(s). What you can't say is that x(t)y(t) corresponds to X(s)Y(s).
You want to use partial fractions to split your X(s) up into a sum of terms you can invert using the tables.
$$X(s) = \frac{1}{s^2(s^2+\omega^2)} = \frac{A}{s^2} + \frac{B}{s} + \frac{C}{s^2+\omega^2} + \frac{Ds}{s^2+\omega^2}$$
So, as I understand it. I have s=0, 0, -w, w.
s2*1/(s2(s2+w2)) evaluated at s=0
So, then I'd have A = 1/w2
This gives me:
s/(s2+ wn2) * 1/s3
cos(wnt) * t2/2
How does this look?
It looks wrong. The L.T. of a convolution is the product of the individual L.Ts, so the inverse of a product would be a convolution, not a product. You could, of course, actually carry out the convolution operation to get the correct answer.
Just use partial fractions; it is easier, and it avoids convolutions.
Multiply both sides by ##s^2(s^2+\omega^2)##. You can then set s=0 in the resulting equation. All terms except for the one with A will vanish, so you can solve for A. The rest of the coefficients will take a little more work. Note that with ##s=\omega##, you get ##s^2+\omega^2 = 2\omega^2##, not 0, so setting ##s=\omega## doesn't help you.
So, I multiplied both sides by s2(s2+w2) which left me with:
1 = As2+Aw2
Solving for A I get
A = 1/(s2+w2)
Why was s=0?
Could I do something similar to find B, like use s(s2+w2) on both sides?
I meant multiply this equation
$$\frac{1}{s^2(s^2+\omega^2)} = \frac{A}{s^2} + \frac{B}{s} + \frac{C}{s^2+\omega^2} + \frac{Ds}{s^2+\omega^2}$$ by ##s^2(s^2+\omega^2)##, and then set s=0 to solve for A.
Yes, I did that. You were right. The left side of the equation became 1 whereas everything else but A turned to 0
1 = A(s2+w2)
A = 1/w2
Did we choose w=0 because it as convenient for us, as it left us with only A?
What would be the best method to solve for B?
I had considered multiplying both sides by s(s2+w2) but this results in A being divided by 0 if s=0.
The other terms don't turn into 0. Why do you think they do?
1 = A(s2+w2)
A = 1/w2
Why are you making such heavy weather of this question? You just need the partial-fraction expansion of
[tex]\frac{1}{s^2(s^2+\omega^2)}.[/tex]
and surely you must have done lots of those in Calculus 101. If not, just Google 'partial fractions' to see lots of on-line sources showing you how to do it. It really is not that hard; it just takes a bit of practice.
Because after each term is multiplied by s2(s2+w2)
we're left with
1 = A(s2+w2) + Bs(s2+w2) + cs2 + Dss2
Which simplifies to
1 = As2 + Aw2 + Bs3 + Bsw2 + cs2 + Ds3
evaluating at s=0
We have
1 = Aw2
A = 1/w2
we're left with
Right. This is a lot different than saying that you get ##1=A(s^2+\omega^2)##. I hope you can see that. (If you're going to say you were just setting s=0 in the other terms, then I'd just ask why didn't you set s=0 in the first term then?)
To get the rest of the constants, you can collect the terms:
$$ 1 = (B+D)s^3 + (A+C)s^2 + (B\omega^2)s + A\omega^2$$ and then match coefficients on the two sides. You should eventually get B=D=0 and C=-1/ω2.
