Use of computers in chemical engineering
Chemical and petroleum engineers heavily rely on computers and electronic devices in their work. Daily tasks often involve creating computer models of chemical processes, running simulations of equipment like reactors and separation columns, and performing data analysis. While some roles may not require extensive computer use, many positions involve significant interaction with software for simulations, calculations, and optimization. Control systems, which are crucial in real-world applications, also depend on computer programming and wiring for sensors. Those with a passion for computers can find fulfilling roles in these fields that minimize mechanical work, focusing instead on programming and data analysis, although a solid understanding of math and programming is essential.
nabeel89
I have a passion for computers/ electronics, but i am going for either chemical or petroleum engineering. I want to ask how much do chemical and petroleum engineers use computers and other electronic devices for their work ?
I don't want to do something which involves most of mechanical work. Is my knowledge limited??
thanx...
I'm a chemical process engineer, and I use the computer every day. I make computer models of big chemical factories, I sometimes run detailed simulations of parts of the factory (reactors, separation columns, other pieces of equipment).
My work does not include control systems, but that's even harder to simulate... and always it is simulated before it is built in real.
And then when it is built in real, the control systems are again hooked up to computers. Somebody must write the software, somebody must attach wiring to all the sensors (thermometers, flow meters, pressure meters, chromatographs and other composition-analysis tools).
Of course there are jobs in chemical engineering and petroleum engineering that are totally without computers. But this is a career choice. Nobody is going to force you to walk around in an overall on a site fixing stuff if you rather program stuff or solder some wiring. :D
The answer is a bit late - I only recently joined this forum. Hope it helps.
I am a senior chemical engineering student, and I use computers for simulating, calculating, optimizing all the time (homework and internships). As a chemical engineer you do a lot of data analysis as well, which requires computers. Excel is your friend.
thanx...
Lots of simulation programmers out there however this usually a lot of math and computer programming knowledge - e.g. Physical Chemistry.
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
19K
  • · Replies 46 ·
