Use part 1 of the Fundamental Theorem of Calculus to find the derivative.
The discussion focuses on using the Fundamental Theorem of Calculus to find the derivative of the function h(x) defined as the integral from -3 to sin(x) of (cos(t^3) + t)dt. The correct approach involves substituting the upper limit sin(x) into the integrand and multiplying by the derivative of sin(x), resulting in the expression [cos(sin(x)^3) + sin(x)]cos(x). A key point of confusion was the placement of parentheses, which clarified that only sin(x) should be cubed, not cos(sin(x)). The final simplified form remains cos(sin(x)^3) multiplied by cos(x), as no further simplification is possible. This highlights the importance of proper notation in calculus to avoid errors in computation.
Lo.Lee.Ta.
1. h(x) = ∫-3 to sin(x) of (cos(t^3) + t)dt
2. Okay, I know that you are supposed to replace t with the upper limit, and then I think you multiply that term by the derivative of the upper limit.
So I thought it would be:
cos(sinx)^3 * cos(x) + sinxcosx
But what even is cos(sinx)? I've seen sinxcosx before but not that...
But I put this answer anyway into my computer homework system, and it's counted wrong.
Would you please tell me what I'm doing wrong?
Thank you! :)
Lo.Lee.Ta. said:
1. h(x) = ∫-3 to sin(x) of (cos(t^3) + t)dt2. Okay, I know that you are supposed to replace t with the upper limit, and then I think you multiply that term by the derivative of the upper limit.
Thank you! :)
(cos(sin(x)^3)+sin(x))*cos(x) is not the same thing as ((cos(sin(x))^3+sin(x))*cos(x). Do you see the difference? Which would you say is correct? I suspect you aren't using enough parentheses.
I'll try to use some amateurish tex here to try to emphasize the difference between the important parts. \cos((\sin x)^3) vs (\cos(\sin x))^3 Which one do you want?
You were absolutely right! The parentheses were off!
cos((sinx)^3) should be the right one. I only want to cube the sinx.
The right answer was:
Oh, this may sound dumb, but... if you were to multiply this out, how would it be written?
Could you condense the cosines (to something like cos^2(x)(sin(x)^3) or would it have to remain as cos(sin(x)^3)*cos(x) ?
cos^2(x) means cos(x)*cos(x)... But there are not two x's... So is cos(sin(x)^3)*cos(x) the most simplified version?
Thank you so much for helping! :)
cos(sin(x)^3) is the most simplified version. There's not much you can do with it. There's no trig law that will let you expand it out.
Oh, okay. Thank you so much! :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
