Use ray tracing to determine the location of the image
The discussion focuses on using ray tracing to determine the image location created by a converging lens with a specific object distance and focal length. Participants clarify that the rays should be extended in both directions to find the convergence point accurately. It is noted that if the rays are properly drawn, they will converge on the same side as the object, indicating the image is virtual and upright. One user expresses confusion about the process, but others provide guidance on correct ray diagram techniques. The conversation emphasizes the importance of accurate ray tracing for understanding image formation in optics.
jlmessick88
An object is 6.0 cm in front of a converging lens with a focal length of 10 cm. Use ray tracing to determine the location of the image. Is the image upright or inverted? Is it real or virtual?
According to my ray tracing...there is no image at all...i'm pretty sure that this is correct, but i just wanted to make sure that what I'm doing is correct??
Now way to tell without seeing your drawing.
well the focal point is behind the object...
then when drawing the ray parallel to the axis, the special ray will refract through the far focal point...
the ray through the center of the lens, the ray does not bend, just continues through the lens at a straight line...
these two lines never converge...
and then the ray through the near focal point...well you can't do that since the focal point is behing the object itself...
thus no lines ever converge
When using ray diagrams to find the image, be sure to extend the final rays in both directions. In your example the rays will converge on the same side of the lens as the object.
how could they converge on the same side of the lens as the object
if i draw the ray through the near focal point (which is behind the image itself) the ray would be pointed downward...
the two other rays, if drawn in the same direction (behind the image) they don't converge
here is an image of my ray tracing
oh wow...i didn't know i could do that...thanks!
  • · Replies 16 ·
