Using a Force equation to find out how much WORK is done.
The discussion focuses on calculating the work done by a complex force acting on a 2.0 kg block as it moves horizontally from x=0m to x=2.0m. The force is defined in component form, incorporating both linear and exponential terms. Participants emphasize the need to integrate the force function F(x) to determine the work done, while also noting the coefficient of kinetic friction at 0.05. Clarifications regarding the force function's units and structure are provided to aid in understanding the problem.
  • Understanding of Newton's laws of motion
  • Familiarity with integration techniques in calculus
  • Knowledge of force components in vector notation
  • Basic concepts of kinetic friction and its effects on motion
  • Learn how to perform definite integrals to calculate work done by a force
  • Study the application of Newton's second law in dynamic systems
  • Explore the relationship between force, mass, and acceleration
  • Investigate the effects of friction on work and energy in mechanical systems
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to force and work calculations.
Larin
A 2.0 kg block is acted on by the following force
Force=[(2N/m)x-(5N/m2)x2]{ihat}+[(13N/(1/m2)x2-(6/m)x+7)e-x^2/(2m^2)cos{(2∏)x/3m}]{jhat}
as the object moves horizontally along a surface. In the expression for the force, x indicates the position of the block along the horizontal axis. The coefficient of kinetic friction between the block and the horizontal surface is 0.05. How much work does the given force do on the block as the block moves horizontally along the surface from x=0m to x=2.0m?N is Newtons
m is Meters
I am not sure...
I have not attempted it because I am not sure where to start at all!
What is the function?
That is the force function in component form. Force= (2Newtons/Meter)x...
I am not sure where to even start.
Okay, but where do I start if it is the integral F(x) dx?
As written, the way I parse it, your force formula looks like this:
F = \left [ 2\frac{N}{m}x-5\frac{N}{m^2}x^2 \right ]\,\hat i + \left[\left ( \frac{13 N}{\frac{1}{m^2}}x^2 - \frac{6}{m}x + 7 \right )e^{-\frac{x^2}{2 m^2}} cos(2 \pi \frac{x}{3 m})\right]\,\hat j
The units don't look right for the coefficient of the j term.
I know that the 13N is over the entire 1/m^2x^2-6/mx+7
  • · Replies 24 ·
  • · Replies 19 ·
