Using a pendulum to measure impact energy absorption in materials
  • Context: High School
  • Thread starter Thread starter Haunschmidt
    Impact Materials
7 replies · 10K views
Haunschmidt
Hi,
I'm doing this investigation for school, and i came up with the idea of comparing the effectivenss of different matrials at absorbing impact.
I have an idea about using a pendulum, where i release a bob of known mass at known starting height then let it hit the material. Thus, afterwards if i can record the rebound height then i can find the energy absorbed. (change in Ep= mgh(before) - mgh(after)). Not entirely sure if this is the best method to do this.
I would REALLY appreciate any comments on his, or alternative methods.
Also, I need to write a 2500 word report on it afterewards, so i really need to make it more complex. -i thought about linking with SHM (cos a swinging pendulum and its kinda like damping), or maybe circular motion (i.e find angular momentum or something, but would need w)
Any ideas??
Thanks.
David :smile:
Your idea about using a pendulum weight to measure energy absorbed is fantastic; so much so that I'd suspect you've seen that this is how industrial machines accomplish the same task!
I'm not so sure about your ideas regarding SHM or circular motion (I don't really see what you'd gain from adding this), but I suppose it depends what you're trying to get out of the project.
To the OP: Look up the keywords Izod, Charpy Impact Test. For more on the subject, try to understand how the impact toughness of a metarial can be estimated from its stress-strain curve.
Further
Thanks for your comments. The Izod, Charpy techniques were of great help.
I have decided to go ahead with this investigation, but as i said i am trying to increase the complexity of it also. SHM and Circular motion would help in the actual analysis of the motion and impact. I'm just not sure if they would strictly apply to a pendulum striking an object (i.e. is this a special case of damping??) ? :confused:
Also, I am planning on investigating many materials including: Rubber, foam, wood (different kinds), metals, paper, building material (brick, stone, etc) plastics, different cloth materials, bone. However, in the investigation i will need all these materials in the same dimensions. So, I am at a complete loss as to how i am going to acquire all these materials with the same size and thickness. Some are of course easier then others... but I am not sure a hardware shop would have most.
- Or alternatively would it be possible to state the energy absorbed in terms of energy absorbed per unit width of the specimen. So wouldn't need same dimensions. I'm not sure if that would be possible. ?
Again, i would really appreciate any comments of help..
Thanks
David
As brewnog mentioned before, I don't see where circular motion would fit in, but I guess you can always add some additional information to make things look nicer. :wink:
Stick to wood and metal first, eventually some kind of brick/stone, as you mentioned.
Usually, in a classical Charpy test, the impact strength of a material sample is defined in units [J / m^2], i.e. you have to divide your energy with the area of the cross section at the point of impact.
...it is naturally possible to normalize the energies with the fracture area. However, to be accurate these tests do not produce specimen size independent results (well what does but anyways :biggrin: ), so I'd recommend you keep the dimensions "similar". With the accuracy you're seeking I don't think this is much of an issue, but I'd keep the specimen sizes, say, within 'tens of percents' of each other if possible (with respect to width) and then normalize the results with the appropriate dimension that changes. If you've as radically different materials as it seems this will likely be very much a non-issue but thought I'd mention (if you were comparing similar materials, like 2 different kinds of steels it would definitely be an issue).
From a practical standpoint, it really shouldn't be too difficult to get sample sizes the same. It's not difficult to get the engineering and construction materials cut; and if you really wanted to include things like bone, you could select your specimen size based on what you have around you?
I'm not entirely sure about this, but I suspect that a cut section of bone won't show the same characteristics as an intact bone of the same general size because of the way the stress would be distributed. It might be best to start with a bone and scale the other materials to match. It might be helpful to consult a biologist about it.
