Using an integral to find area of section of a sphere
4 replies · 2K views
Azelketh
(sorry i have not learned latex to display the maths)
Integrating to find the proportion of the area of a sphere that is within the section described by the bounds of theta.
theta is longitude axis angle
-(pi)/9 <= theta <= pi/9
thi is lattitudal axis angle
0 <= thi <= 2 pi
as using the +pi/9 and -pi/9 limits for integration would return 0,
i have used 0 to pi/9 and then multiplied the result by 2.
integral( 0 to pi/9) integral(0 to 2 pi) { 2 r^2 sin(theta) d thi d theta }
= integral( 0 to pi/9) { 4 pi r^2 sin(theta) d theta }
= 4 pi r^2 [-cos(pi/9) - cos(0)]
= 4 pi r^2 [-cos(pi/9) - 1] = 0.06... *(4 pi r^2)
this must be incorrect however as the fraction of the surface of the sphere should surely be fraction of the angle. eg the top half of the sphere should have 1/2 the surface area, so if the range of theta is 2pi/9 surely the area of the sphere should be (4 pi r^2)* [ ( 2 pi / 9 ) /pi]
should therefore be 8 pi r^2 / 9
can anyone point out where i am going wrong in the integral or my thinking?
area element = r^2 sin(theta) d theta d thi
is this more correct? with the order of the d thi and d theta reversed? this shouldent make any difference though if the correct set of limits for the integrals are used.
You may wish to consider computing the area via surface of revolution by revolving the segment of the curve [itex]x^2+y^2=r^2[/itex] around the x-axis between [itex](\pi/2-\pi/9, \pi/2+\pi/9)[/itex]
Just seems easier that way.
problem solved, it was just the integral limits which were the wrong way around, also as cos is an even function istead of integrating over 0 to 2 pi which would return 0, integrating from 0 to pi and doubling the result gives the correct answer.
Thanks for your suggestions dudes.
