Using Correlation to Predict Values
  • Thread starter Thread starter Soveraign
    Correlation
Soveraign
I've searched the forums but am unable to find an answer to this:
Given two variables with a correlation, you can predict one from the other using the familiar
E(Y|X) = EY + r * s_y * (X - EX) / s_x
What I want to know is how to predict values from multiple variables, especially when these variables themselves are correlated.
E(Y | A B C) = ??
You example shows computation for the expected value of a random variable, but you are using the word "predict" to phrase your question. Are you trying to "predict" the value of a random variable Y given the values of other random variables? Or is your goal to compute the expected value of Y give the distribution functions for other random variables?
You are correct, I am looking to calculate the expected value of Y given A, B, C and known correlations YA, YB, YC, AB, AC, BC (and necessary variances, etc...)
I've only seen that formula applied to random variables that have a joint bivariate normal distribution. Are you assuming all the random variables in your question have a joint multinormal distribution?
If I understand the definition correctly, then I think so. Y, A, B, C are normally distributed about a mean, but not necessarily independent (i.e. covariance != 0).
A thought I had was to perform principle component analysis on A, B, C so I then would have some new (independent) eigenvectors to work with. Perhaps then I could do multiple regression with my new A', B', C' working out an n-1 dimensional "plane" through my n space, thus working out E(Y|A', B', C')?
But I assume this is a solved problem and I'm just not looking in the right places.
I looked too. I think this page (in the section called "The Multivariate Normal Distribution") gives the answer, but I haven't deciphered all the matrix notation.
As I recall, the fact that the marginal distributions are normal does not guarantee that the joint distribution is a multivariate normal. So you need to examine this assumption.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
