Using Curl to determine existence of Potential Function
The discussion clarifies the relationship between the curl of a vector field and the existence of a potential function. A zero curl indicates that a potential function exists only if the vector field is defined on a simply connected region in R3. Conversely, a non-zero curl guarantees that no potential function exists. The Poincaré lemma is referenced, highlighting that the domain's topology significantly impacts these conclusions. Overall, the existence of a potential function is contingent upon both the curl value and the nature of the vector field's domain.
Ineedahero
How does it work, exactly?
Assume I have a vector field function and I take the curl of it.
If I get a curl of zero, then does that guarantee that there is no potential function?
And if I get a curl of non-zero, does that guarantee that there is a potential function?
I googled this, but it wasn't clear.
Thanks.
You are mixing things up. As far as calculus on ##\mathbb{R}^{3}## is concerned, if ##X## is a smooth vector field defined on a simply connected region in ##\mathbb{R}^{3}## and ##\nabla \times X = 0 ## then there exists a smooth scalar field ##\varphi ## such that ##X= \nabla\varphi ## on that simply connected region. However if the vector field is defined on a non-simply connected region then this need not hold true.
If the curl of the vector field is non-zero, how can the vector field be the gradient of a scalar field?
More generally, we speak of exact and closed differential forms. The result on ##\mathbb{R}^{3}## can be generalized to smooth manifolds using the rather beautiful Poincare Lemma: http://en.wikipedia.org/wiki/Closed_and_exact_differential_forms#Poincar.C3.A9_lemma
EDIT: Note that we make use of the above in electromagnetism all the time because the electromagnetic field ##F## satisfies ##dF = 0 \Rightarrow F = dA## (at least locally) and we call ##A## the electromagnetic 4-potential.
Thanks for the quick response!
So, I take it that the following statements are true (assuming the vector field is smooth and connected in R3 and so on):
If the curl is zero, then that GUARANTEES that there IS a potential function
If the curl is non-zero, then that GUARANTEES that there is NO potential function
Likes immortalsameer13
No. But this is a very tricky subject. A lot depends on the domain of the vector field ##X##. For example, if ##X## is defined on entire ##\mathbb{R}^3##, then it's true: if ##curl(X)=0##, then there is a potential function. But if ##X## is defined on ##\mathbb{R}^3\setminus \{0\}## (for example), then there are counterexamples.
The Poincare lemma states that if the domain of definition of ##X## is convex (or more generally: star shaped), then it is true that if the curl is zero, then there is a potential function. But on more general domains, this might fail.
The study of this question is done in De Rham cohomology. This is a formalism set up to study the situations when ##curl(X)=0## implies the existence of a potential function.
This is true.
  • · Replies 20 ·
