Using first principles, how to get the equation of motion?
The discussion focuses on deriving the equation of motion for a mass on a spring, incorporating linear resistance and driving forces. The equation is expressed as d²x/dt² + 2K(dx/dt) + Ω²x = F(t), where F(t) = G(t)/m, Ω² = α/m, and 2K = β/m. Participants emphasize the importance of clearly defining parameters such as S, R, K, Ω, and F(t) to facilitate understanding. The conversation highlights the necessity of expressing the sum of forces in terms of mass and acceleration to derive the equation from first principles.
  • Understanding of Newton's second law (ΣF = ma)
  • Familiarity with linear differential equations
  • Knowledge of spring constants and damping forces
  • Basic concepts of forces and motion in physics
  • Study the derivation of differential equations in classical mechanics
  • Learn about the concepts of damping in oscillatory systems
  • Explore the relationship between force, mass, and acceleration in depth
  • Investigate the implications of linear resistance on motion equations
Students in physics, particularly those studying mechanics, as well as educators and anyone interested in understanding the dynamics of oscillatory systems with resistance.
Nicci
<< Mentor Note -- thread moved from the technical forums, so no Template is shown >>[/color]
Show, from the first principles, that the equation of motion of a mass (m) on a spring, subjected to a linear resistance force R, a restoring force S, and a driving force G(t) is given by
d2x/dt2+ 2K(dx/dt) + Ω2x = F(t)
I started by saying S = αx and R = βv.
ma = G(t) - S - R = G(t) - αx - βv where a = (d2x/dt2) and v = (dx/dt)
I am a bit confused on how to use the first principles to derive the equation. Usually for first principles I would have a function like f(x) and then I would use f(x+h), but I am stuck on this part. I did try to use G(t) and G(t+h), but that did not work.
Can someone maybe give me a hint on how to use the first principles in this case? I am sure I will be able to derive the equation if I can just figure out the next step.
Thank you very much in advance.
Hi Nicci. Welcome to PF!
Can you provide us with the exact wording of the question? I am not clear on what F(t) is.
AM
AM
"Show, from the first principles, that the equation of motion of a mass (m) on a spring, subjected to a linear resistance force R, a restoring force S, and a driving force G(t) is given by
In your discussion, clearly define S, R, K, Ω, and F(t)."
This is the exact words of the question.
In the textbook it states that:
F(t) = G(t)/m
Ω2 = α/m
2K = β/m
Thank you very much.
You haven't given any reason for introducing new parameters α and β so why do so?
Other than that, start with ΣF = ma. What is a in therms of x?
How about velocity? In terms of x? And where does G(t) fit in?
So rewrite ΣF in terms of x with the given parameters (typically constants except for G(t).
The rest should flow freely.
F(t) = G(t)/m
Ω2 = α/m
2K = β/m
So α is the spring constant (usually denoted as k) which is potentially confusing. Also, F is an acceleration not a force, which can cause confusion.
Do as rude man says and express the sum of all forces in terms of the total mass x acceleration. There are 3 different forces ie:
∑Forces = ma = Applied force + Resistive force + Restorative Spring force
Spring: Let the equilibrium point be 0. How is the restoring force related to x?. Hint: Where is the restoring force always directed toward?
Resistive force: It is not clear from the problem as stated, but this force is a linear function of speed. What is its direction in relation to the speed direction?
Applied force: G(t) is an applied force that is not a function of x.AM
Thank you very much. I will define the new parameters and all the other terms.
Thank you very much. It looks like I am on the correct path. I will just define my parameters and other terms.
May you please send me all your solutions 8 am struggling with this question also
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 32 ·
