sylent33
- 39
- 5
- Homework Statement
- When a resistor R is connected, the terminal voltage of a battery is equal to
U = 4.3 V and the power in the resistor P = 2W. The battery is said to be ideal
Voltage source can be modeled with internal resistance.
a)What is the internal resistance Ri of the battery if its source voltage Uq =
4.5 V?
b)At which load resistance would the terminal voltage be U = 4 V?
cYou connect a second, identical battery in parallel. How does the power change from point a)? Draw the circuit and label all sizes.
- Relevant Equations
- P = UI
Okay so This is what I've tried;
a) A formula I've found in the lecture notes;
$$ U_a = U_q - R_i*I $$ To get I used the ## I = \frac{P}{U} ## formula I get I to be 0,46 A.Now put back in formula for and rearange to get Ri should be
$$ \frac{Ua-Uq}{I} = Ri $$ and the solution should be 0,43 Ohm.
b) I used the same formula as in the first one but here I simply rearanged to get I
$$ I = \frac{Uq-Ua}{Ri} $$ I = 1,16; and now ## R = \frac{U}{I} ## = 3,44 Ohm.
Now I think these two should be fine,I've checked the work with a few friends and it matches.
c) Here I am having problems.I've drawn the picture and I've tried a few things but I am not really having much succsses with it; This is my picture;(attachment) Now P should be 2,09W but I don't see how.What I've tried is adding both currents since they both are going in the same knot(above I2) and I Kirchoffs Law.With that new current,I've tried finding P but the value is not correct.Any insights? Thanks
