Using Laplace Equation in one dimension to solve for a charge-free slab
6 replies · 3K views
hansbahia
An empty (charge-free) slab shaped region with walls parallel to the yz-plane extends from x=a to x=b; the (constant) potential on the two walls is given as Va and Vb , respectively. Starting with LaPlace's equation in one dimension, derive a formula for the potential at any point in the region
d2V/dx2=0
I get the whole concept how they get the average potential since if we were to integrate twice laplace equation we would get two integration constant
d2V/dx2=0
dV/dx= a
V = ax + b
and if we were to average from V(x+a) and V(x-a) we would get
V (x) =1/2[V (x + a) + V (x-a)] and you can use for any point within
how did the answer to this problem came out to be
V(x)=[Vb-Va)x+Vab-Vba]/b-a
d2V/dx2=0
d2V/dx2=0
dV/dx= a
V = ax + b
You are using the symbols a and b to represent two different things. If you represent the potential by
V = Cx + D
and use the two boundary conditions to solve for C and D, you get
V = Va + (Vb - Va) (x -a)/(b -a)
which is the same as the answer you were trying to match.
Chestermiller said:
V = Cx + D
So if at we have Q+ at a and Q- at b, from a to b Vb=0 and at a the potential will be Va or we have a distance of d from a to b, Va=Qd/Aε0.
So V(x)=C(x)+D
at V(0)=0+D
D=Vb
but you got D as Va?
How did start solving for C? What boundary conditions?
Sorry, I totally forgot that is a charge free slab. Therefore I'm still stuck on the boundary conditions
How come your results is equal to the answer? Va is not part of it
Va is the voltage at coordinate x=a.
V = Cx + D
Va = Ca + D
This is no longer a physics problem. It has been boiled down to strictly a math problem. The question is, are you capable of solving the following second order ordinary differential equation:
d2V/ dx2 = 0
subject to the following split boundary conditions:
V = Va at x = a
V = Vb at x = b
Well,...can you?
Chestermiller said:
d2V/ dx2 = 0
V = Va at x = a
V = Vb at x = b
Well,...can you?
Yes I can
Since we have the boundary conditions
V = Va at x = a
V = Vb at x = b
Va=Ca+D
Vb=Cb+D
Set D=Va-Ca
Solve for C on Vb
Then solve for D. Then just plug in Vx
Thanks a lot!
