Using Nodal Analysis to determine current in a resistor
1 reply · 3K views · last reply
TheBigDig
Circuit schematic labelled Figure Q7: a 9 A current source and resistor R with 10 Ω in parallel, an 8 Ω resistor and a 3 Ω resistor along the top, a 6 Ω resistor in the middle branch, and a 45 V voltage source on the right.
##V = IR##
##\sum_{k = 0}^{n} I_k = 0##
Handwritten circuit schematic with a 9 A current source, resistors 8 ohm, 10 ohm, 6 ohm and 3 ohm, a 45 V source, currents I1 to I4 marked with loop arrows, and reference node Vr = 0, with node and loop equations below.
[/B]
I set the bottom node as the reference node and worked from there to find the three equations for the loop. When I try to eliminate ##I_4## by using ##I_4 = I_2 - I_3## I run into a problem were both ##I_2## and ##I_3## scale equally are both eliminated from the simultaneous equation. I tried manipulating ##I_1## to solve it but got the wrong answer. Any help would be appreciated as I am new to nodal analysis.
You're doing loop analysis (KVL) but they want you to use nodal or source transforms.
Can you write node equations using the given component values? The only variables you should introduce are the node potentials. No current variables!
