Using the Frobenius method on a 2D Laplace
The discussion revolves around applying the Frobenius method to solve a 2D Laplace equation. Participants are addressing issues related to notation and the proper setup of the differential equation.
  • Mixed
  • Participants discuss the confusion arising from using the symbol ##\ell## in multiple contexts and suggest using a different summation variable. There are hints provided to simplify the equation and guidance on plugging in the Frobenius ansatz into the ordinary differential equation (ODE) to compare coefficients.
Some participants have provided hints and suggestions for clarifying the problem setup. There is acknowledgment of confusion regarding notation, and one participant reports successfully resolving their issues after revisiting the problem.
There is mention of imposed constraints on notation and the need for clarity in variable representation, which may affect the understanding of the problem.
jkthejetplane
I have some supplemental hmwk that I need to use a method I am not familiar with and I am not sure I have applied it correctly bc if i solve for the missing variable i will not achieve the right answer.
Frobenius method of solving ode
The problem is you're using the symbol ##\ell## in two different ways: (1) as part of the constant that appears on the righthand side of the differential equation and (2) as the index of the summation.
  • Haha
Hint:
$$\frac{\mathrm{d}}{\mathrm{d} r} \left (r^2 \frac{\mathrm{d} R}{\mathrm{d} r} \right)=r \frac{\mathrm{d}^2}{\mathrm{d} r^2} (r R)$$
helps to make the equation simpler.
Then you have to choose another summation variable in your Frobenius ansatz than ##l##, e.g.,
$$R(r)=\sum_{j=0}^{\infty} a_j r^{j+\lambda},$$
and you can assume ##a_0 \neq 0## for uniqueness. Then plug this ansatz into your ODE and determine first ##\lambda## and then the ##a_j## by comparing the coefficients in the generalized power series on both sides of your equation.
vanhees71 said:
Hint:
Ok so as far as your hint goes, I should be using that whole expression by getting it equal to zero so I have a y" term or that I should only use the right side equal to 0?
Oh yeah i see that now. I got caught up in our notation and other notation when looking up the method. I'll try again using the standard n
Just plug in the ansatz into the equation and compare the coefficients of the series. You'll get an equation for ##\lambda## and then a recursion relation for the ##a_j##.
Update: I got it all correct after just trying again without the confusion of l terms. Did it a couple ways to make sure. Thank you
  • · Replies 19 ·
